      05-20-2022, 06:33 PM   #1
mothy5000
mothy5000's Avatar
Drives: '08 BMW Z4 3.0si E85
Transmission Shifting Issues
My '08 Z4 currently has 128k miles with an automatic transmission. Every now and then when I'm driving it will hesitate at lower speeds. This is mainly when the trans is in 2nd getting ready to move to 3rd. This has happened twice. Once 2 weeks ago and then again last night. I don't see any transmission codes. Just Valvetronic, eccentric shaft sensor codes.
Does this sound like a transmission issue or something else? I have had the trans fluid and filter changed. TIA
      05-22-2022, 09:32 AM   #2
wdb
dances with roads
wdb's Avatar
Drives: '07 E86, '07 E93, '02 996
Those codes are engine codes.
      05-22-2022, 03:42 PM   #3
mothy5000
mothy5000's Avatar
Hence me pointing out they are not transmission-related.
      05-22-2022, 05:10 PM   #4
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Both of those engine codes could cause those issues. Valvetronic kicks in around 2800rpms if I remember right. Could always be the vanos solenoids too. Doubt it's the trans at least I hope not for your sake. If it is just plan on doing a 6spd swap. My 3.0si hesitated until I PCV so it could be that as well. Depending on if yours is the gray or black top valve cover will decide if you have the CCV or the built in PCV.
Do you get rpm bounce at start up?
      05-22-2022, 07:47 PM   #5
wdb
dances with roads
wdb's Avatar
So then what makes you think your problem is the transmission?
Search this Thread:
Advanced Search
Copyright ©2000 - 2022, vBulletin Solutions Inc.
