05-21-2022, 03:33 AM | #1 |
Rep 33
BMW Z4M fuel system upgrade
My ///M becomes FI and will run on E85 fuel (I upgraded my fuel pump to WALBRO HELLCAT 525LPH).
I want to upgrade the entire fuel system of my ///M with radium components in order to support it in the best and safest way. I have already radium s54 fuel rail + fuel flex. Does anyone have experience with this and can help me choose the right components? (PushLok Hose Ends, DMR, Fuel Pulse Damper and etc...) |
05-21-2022, 04:21 AM | #2 |
#buildnotbought
10773
Rep 4,890
whatever you do with pushlok, always use a hoseclamp on those barbs, even though they say it's not needed.
05-21-2022, 01:07 PM | #3 |
Down Under!!
1621
Rep 4,294
This!! Exactly!
Btw, you need the radium fuel pulse damper otherwise you'll get erratic injection if your running that rail. I have the same setup on mine and I love it. There's also the surge pump from radium that's a good buy, esp.if your running e85. Bit exy, but well worth it. |
05-21-2022, 01:22 PM | #4 | |
Rep 33
1. My fuel lines will be 6AN so I'm guessing I'll need the "FPD-XR, Inline, 6AN" option: http://www.radiumauto.com/Fuel-Pulse...Kits-P751.aspx 2. Can you provide a link the surge pump from radium? Will it work with WALBRO HELLCAT 525LPH? |
