      01-14-2008, 12:55 AM   #1
Alpine M
Drives: Silver/Red Z4MC
Sway Bars - Who has installed them? Please come inside.
Hi everyone,
I am starting to modify the coupe finally (got 2,500 miles on her already). Anyhow, with my old 350z the single-most impressive modification that I did to that car was the addition of a set of Hotchkis sway bars (bang for the buck).
I am wondering if the M coupe will see the same benefit. I see the advertised stiffness increase vs. 3.0si sport, but not vs. M. So I am not sure how stiff the existing M bars are.
If any owners have installed these on any of their coupes, please share your thoughts on the results.
Thanks,
Jim
      01-14-2008, 01:32 AM   #2
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
http://www.zpost.com/forums/showthread.php?t=93894
      01-14-2008, 03:11 PM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Uh, he said Sway Bars not Strut Bar. The link you sent him to is for a strut bar. I've never seen a thread for sway bar install didn't know anyone made one either.
      01-14-2008, 03:23 PM   #4
vachss
Drives: Z4 Coupe
I know H&R and Hotchkis make bars for the Z. Stock diameters on the 3.0si are 25/19mm F/R (24/18mm for non-Sport) and the aftermarket bars are something like 27/21mm. I believe the torsional stiffness of a bar varies with diameter squared so if the end link geometry is the same I'd say the stiffness of the aftermarket bars is something like 15-20% greater than stock. Aftermarket bars are usually adjustable though, so this is just a first cut.
Update: A couple of things. First the M bars are significantly thicker than those on the 3.0si - realOEM says 27/22.5mm F/R. Also while 27/21mm is correct for the H&R bars, the Hotchkis are quite a bit bigger. Here's specs I downloaded...
Specifications:
- Front 28.5mm Tubular 3 Position Adjustable
- Stiffness: +19%,+38%+61% (Compared to stock Z4 Sport)
- Rear 24mm Tubular 2 Position Adjustable
- Stiffness +59%, +86% (Compared to stock Z4 Sport with 24mm front and 19mm rear)
It looks like the aftermarket bars I'm seeing are for the non-M Z4s. I don't know if the M and non-M bars are interchangeable. Regardless, it looks like the H&R bars are roughly the stiffness of the stock M bars, while the Hotchkis set up is subtantially stiffer than either. It would be nice to find out if the M and non-M bars are swappable as lots of us 3.0si drivers would probably just as soon install stock M bars as an aftermarket kit.
Update 2: A careful reading of realOEM shows that the part numbers for the end links the sway bars fit into are the same for the M and non-M Z4 coupes. I suspect this means that they are interchangeable (but somebody should definitely verify this before ordering anything).
      01-15-2008, 07:18 PM   #5
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
I have the hotchkis sway bars myself and absolutely love them. They really did a job on stiffening up the ride and reducing body roll. But in comparison to the ///M factory bars, it appearss to be a very small upgrade. Maybe the difference won't be as noticable. And then there is the question of fitment as well. I thought that the ///MZ4 shared most of its rear suspension from the M3?
      01-15-2008, 09:26 PM   #6
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
sorry . control arms ftw
      01-15-2008, 09:52 PM   #7
Alpine M
vachss,
Thank you for the very detailed reply!
I'll pick up a set and report back soon.
Jim
      05-10-2009, 09:12 AM   #8
nlink720
Drives: 2004 BMW Z4 Roadster
Bringing this post back a little bit.
For those who have added sway bars, I just want to confirm something: It should be a noticable reduction in body roll, right??
I upgraded my front only, since SCCA permits fooling with the front only in stock classes. My goal was to reduce body roll and a host of other things that should be beneficial despite the potential for increased understeer.
I have the H&R bar at the stiffest setting and noticed zero difference.
I cannot see any damaged end links or other problems, but felt there should be at least some noticeable difference. The difference between 3.0i sport and H&R is still a few mm in thickness... something seems strange, and the body roll still exists.
FS: Leather Recaro Pole Position Seats & Hardware
      05-10-2009, 05:40 PM   #9
xg3
Drives: Was 03 Z4, now 10 GTI
in my last car, mazda 3.. sway bar was more effective than springs in reducing bodyroll...
only reason i havn't done it to the Z4, is i was "hoping" for the same result, but you just gave me doubt..
can someone please confirm?
      05-16-2009, 06:37 PM   #10
nlink720
To clarify my previous post: there IS a very noticable difference with the front sway only. My observations were skewed because I had a bad sway bar link.
After replacing that, the front is way tighter. It understeers like hell, but for daily driving it is way better. I am referring to H&R at the stiffest setting.
Another unintended benefit is that the steering wheel feels heavier and more precise.
I want now to get the rear as well, but first have to review the scca categories that I could compete in should I do the rear.
      05-19-2009, 02:44 PM   #11
Incompatible
Drives: 07 AW Z4C 3.0Si
Originally Posted by vachss View Post
..... It would be nice to find out if the M and non-M bars are swappable as lots of us 3.0si drivers would probably just as soon install stock M bars as an aftermarket kit.
Did anyone ever determine if the M / nonM (3.0Si) bars are interchangeable?
      05-21-2009, 03:18 PM   #12
Haretakis
Haretakis's Avatar
Drives: 2007 Silver Z4 M Coupe
Talk to Palantirion about his Ground Control sways...he knows his stuff.
ESS Tuning Software, JVT (Ebay) Headers, AFE Intake, RPI Scoop, ACS Pedals, and ZHP Shift Knob.
      05-21-2009, 04:08 PM   #13
Incompatible
Good advice, should have talked to Earl first thing. Thanks.
      05-26-2009, 01:22 PM   #14
chinkwan
Drives: Z4 M
What about the M Coupe bars?? THis is for the M roadster crowd..
I think I read somewhere that the M Coupe Bars are thicker then the M Roadster?? Is that true??
Also, can somebody find out about the Ground Control Sways? I read from the OTHER forum that it needs to be modified to fit our cars???
      05-26-2009, 01:44 PM   #15
vachss
Drives: Z4 Coupe
The rear bars are not at all interchangeable (shaped to fit around different differentials). The fronts aren't exactly the same, but the M bars are said the be usable on the non-M "with minor modification". I haven't physically examined an M and non-M front bar together, but this info comes from the folks at BMS who have.
