      04-01-2020, 11:52 AM   #397
B328iC
Drives: 97 328iC, 2003 Z4
Originally Posted by UNFORGIVABLE View Post
Okay. I read every post in this thread and I still have a question. I'm looking to pick up a set of these wheels
18x9.5 et35 (Square)
245/35/18
Car: e85 3.0 roadster.
I did all the calculations showing how much more aggressive these will be compared to stock but the front seems a bit too aggressive.
I plan on lowering with coilovers at some point. I can handle rubbing, I just dont want the car looking ridiculous with poke up front.
My question is really about the front. Is that too aggressive? Need a fender roll? Dont buy?
I'm curious on this as well. Have no plans on lowering or changing from the stock set-up. How would his work on a 2003 3.0 roadster?
      10-06-2020, 08:28 AM   #398
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
NUMBERS!...for those looking in the future:
Stock Front 18 x 8.0 ET47 // 225/40R18
Stock Rear 18 x 9.5 ET50 // 255/35R18
Rotiforms Front 19 x 8.5 ET35 // 235/35R19
Rotiforms Rear 19 x 10 ET40 // 265/35R19
Hypergram Front 18 x 8.5 ET35 // 235/40R18
--6mm more clearance than stock on inner, same as Rotiform
--18mm extended outer over stock, same as Rotiform
Hypergram Rear 18 x 9.5 ET35 // 265/35R18
--2mm more clearance than stock on inner, 11mm more clearance than Rotiform
--28mm extended outer over stock, 1mm less extended than Rotiform
Ultraform Front 18 x 8.5 ET38 // 235/40R18
--3mm more clearance than stock on inner, 3mm more clearance than Rotiform
--18mm extended outer over stock, 3mm less than Rotiform
Ultraform Rear 18x x 9.5 ET36 // 265/35R18
--1mm more clearance than stock on inner, 27mm more clearance than Rotiform
--27mm extended outer over stock, 2mm less extended than Rotiform
Front Tires:
225/40/18 - stock
--DIA 25.09"
--CIRC 78.81"
235/35/19
--DIA 25.48"
--CIRC 80.04"
235/40/18
--DIA 25.40"
--CIRC 79.80"
Rear Tires:
255/35/18 - stock
--DIA 25.03"
--CIRC 78.63"
265/35/19 (hard to find from some manufacturers)
--DIA 26.30"
--CIRC 82.63"
275/30/19 (running as of May 2019, same rims no issue)
--DIA 25.50"
--CIRC 80.10"
265/35/18
--DIA 25.30"
--CIRC 79.49"
(Hoping to run at some point)
Pirelli PZERO Slicks "DH"
Front
235/645/18
--DIA 25.40"
Rear
265/645/18
--DIA 25.40"
Currently on the search for more meat in the front end without rubbing.
Current track setup for front:
Option is to run the current rear setup on the front as well:
--11mm LESS clearance than current front setup
--EXTEND an extra 15mm over current front setup.
-Compared to stock
--8mm LESS clearance than stock front setup
--EXTEND an extra 30mm
--Technically this would only extend past my rotiform 19" setup by 12mm
I'm thinking this is doable, worst case may rock more camber for the track.
I have not tested this, but I will and report back.
      10-16-2020, 12:04 AM   #399
BMilton
Drives: BWM Z4 Coupe
18x8.5 et35
255/35/18
[img]https://live.staticflickr.com/65535/...0b0bdd8b_k.jpg[/img]
[img]https://live.staticflickr.com/65535/...5a1bbda7_k.jpg[/img]
[img]https://live.staticflickr.com/65535/...39590404_k.jpg[/img]
3GFX722.50
      11-19-2020, 10:25 AM   #400
vismajeure
Drives: 2023 G4 230i; 2006 Z4 E85 3.0i
HRE FF15
Just got these.
HRE FF15 in Tarmac
19x8.5 +40 225/35
19x9.5 +44 255/50
Koni Yellows with H&R springs.
Not flush and may add small spacers. Not sure yet on whether I want to keep the wrapped A Pillars and Side Sill Decals.
3GFX722.50
      01-05-2021, 07:02 PM   #401
z4ninja
Drives: 2003 bmw z4
Originally Posted by jimbob0047 View Post
513m fits the non m z4 perfectly. Not with oe m3/m4 255/40 and 275/40 tire sizes though. Rear was fine but rubbed two holes in the front fender liners on stock suspension. Had to step it down to 245/35 and 265/35 which is the closest to factory diameter as well. Allowed for some coil overs and lowering. First two pictures are with the oe tires and suspension, last two are with stepped down tire sizes and lowered on bc coil-overs.
hello, i was wndering if you are still active, i want to get these rims but im not sure what size and brand to get, i also have a 2003 bm,w z4 3.oi with sport suspension i believe
      01-07-2021, 07:41 AM   #402
KLEETIS
Drives: 2008 BMW Z4si Sport Package
New Need Help!
I also read all the threads but still unable to figure out if stock wheels Width on my 2008si Sport packge wheels are front 18"X 8.5" ? and the Back 18"X 9.5" ?
Can I change the front tires 225/40R18 to 235/40R18 without rubbing??? and can I change the rear tires 255/35R18 to 265/35R18 without rubbing??? This is why I'm asking the rim width so not to pull the side walls in. I thought this would be easier to figure out using the tire size calculator they seem to me they will fit without rubbing but not really sure. Has anyone done this?
Any help would be apprecated!
Attachment 2499718
      01-07-2021, 11:37 AM   #403
Steeler
Steeler's Avatar
2429
Attachment 2499718
Put the last 7 digits of your vin here https://www.realoem.com/bmw/enUS/select
It will tell you the rim style, diameter, width and offset of your stock wheels.
I ran the same tire sizes on the same width rims that you are noting. Albeit with different and more aggressive(wheel pushed outward) offsets to stock.
Lowered 1"
I did not experience rubbing.
3GFX722.50
      04-23-2021, 05:35 PM   #404
JB02tii
Drives: 2008 BMW Z4 Coupe 3.0si
I am a new owner of a 2008 E86 Z4 coupe. I am interested in putting an 18" square setup on my car... in particular the Flow One Race Spec 18x8.5 ET40. What tires size will work for this rim and a stock sport suspension. Thanks!
      05-28-2021, 02:47 PM   #405
3GFX
3GFX's Avatar
-Compared to stock
Update
Rear wheels caused WAY to much poke on the front. As expected.
So I decided to maximize tire on the existing rim. I will report back with findings, pray for no rub. Keep me in your prayers ehehehe
Ultraform Front 18 x 8.5 ET38 // 255/35R18
Ultraform Rear 18 x 9.5 ET36 // 275/35R18
I went with Nankang AR-1 for a second time now, loved em for the track last season.
      06-30-2021, 10:06 AM   #406
breener96
Drives: 2007 BMW Z4M
nice
      01-21-2022, 08:29 PM   #407
fanchazstic
Drives: BMW Z4 3.0si 2006
I've always wanted a set of TE37's, but I'm having a hard time finding a good front set. I found some 18x8.5 ET35, but they don't come in the color I want, or even a color that could match the rears. My options are either try to fit 18x9.5 ET38 in the front (which come in plenty of different colors) or get the 18x8.5's and have all 4 wheels powder coated (doubt I'd be able to color match to the rears). I'd have a real hard time stripping the factory finish off a brand new set of Volks though. So ultimately my question is: can the 18x9.5 ET38 work in the front of a 2006 3.0si (currently stock ZSP) or would it be wiser to go with the 18x8.5? I do plan to lower the car on coilovers so if that's required then that's no issue. The car is a street car so I don't want crazy camber eating up tires, but some camber isn't an issue. My main concern is performance. I don't track the car but most of my driving is spirited backroad driving, so I don't want to sacrifice on that. Hoping to get opinions from people with more experience because I have very little. Any advice is appreciated. Thanks.
      02-21-2022, 10:54 AM   #408
Gdubs22
Drives: BMW e85 z4 2.5i
Fitment Question
Hey everybody, I am looking to run apex arc-8 17x8.5j et40 on all four corners with yokohama advan v601 tires sized at 245/40/R17. So would be a square setup. My car is lowered 15mm from factory sport suspension on the Bilstein b12 kit. Camber is stock. Wondering if this should fit?
      02-25-2022, 02:21 PM   #409
3GFX
3GFX's Avatar
Did you spend any time going through this thread to see similar specs?
Did you search the thread?
Pretty sure they'll fit. That tire might be too wide for the rim IMHO.
EVEN better though:
https://support.apexraceparts.com/hc...-Fitment-Guide
      05-08-2022, 11:55 AM   #410
Gdubs22
My new setup
Here is my new Apex setup
http://www.zpost.com/forums/showthread.php?t=1921278
      08-04-2022, 07:24 PM   #411
Mr. Monday
Drives: Z4C 3.0si 6mt
Hey Zpost community, I'm looking to replace my tires because I'm rubbing with the tires that came on my E86. I'm running Enkei Raijin wheels 18x8 ET42 in the front and 18x8.5 ET38 in the rear. I would like to go with wider tires than stock to protect my rims. Would 235/40R18 front and 265/35R18 in the back fit? I was rubbing before because my tires were too tall but I'm wondering if I'll rub with stock height but extra width. Edit: I have stock sports suspension
      09-08-2022, 05:02 AM   #412
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
Read through a lot of this thread and the apex fitment recommendations.
While it appears many people run 17 or 18 x 8.5 or 9 et30 to et35 w/ 235/40
Why not 245/35 or 255/35 square? It seems like that would fit better and provide more grip
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
      09-08-2022, 11:09 AM   #413
Piper1
Piper1's Avatar
Drives: E85
255/35 will rub on the front liners and require camber plates. If you’re ok with that then sure. I’m on 18x9 et31 apex ec7 squared Toyo r1r 255/35/18 on my roadster on koni yellow adjustables / eibach springs.
Edit: also like to add when talking about more grip when going wider pay close attention to your tire selection specs. Look at “tread width”. You’ll find out real quick that not all 255 width tires and so on when comparing sizes are created equal on width of footprint. Pending tire comparisons there are 275 width that have less tread contact than some 255s and so on. So certain 245 tires also will have more contact patch than some 255s.
      09-23-2022, 01:11 PM   #414
mex777
mex777's Avatar
Romania
Drives: BMW Z4 E85 3.0i
OZ Formula HLT
18x8 ET45 235/40R18
18x9 ET40 265/35R18
      11-27-2022, 12:08 PM   #415
B328iC
I need input on this. I have a 2003 E85 with the M sport suspension. I'm looking at getting rid of the stock staggered setup on 107's and switching to Alzor 881 staggered setup.
Rims Ft: 18"x8.5" ET35 and rear 18"x9.5" ET35. I'm also wanting to use Extremecontact Sport tires 235/40/18 front & 265/35/18 out back.
I don't want any kind of spacers so the question is fitment without problems. Anybody have picts of this setup or can offer any insight as to fitment.
      11-27-2022, 02:29 PM   #416
Steeler
Steeler's Avatar
2429
I used those exact same offsets, wheel size and tire sizes on my non M for one of the first combos I tried.
Lowered approx 1" front and rear. No issues with rubbing.
Pardon the fuzzy pic.
      11-27-2022, 04:34 PM   #417
B328iC
How interesting as mine is also Maldives blue. How did you like the combo?
      11-27-2022, 06:04 PM   #418
Steeler
Steeler's Avatar
2429
I really liked the upsize in tires compared to stock.
Car handled well.
