      10-05-2019, 07:18 PM   #1
kermmmit
Drives: BMW Z4 M
Stock Ride height z4 m roadster
Any of you guys know stock Ride height from center cap to fender ?
      10-05-2019, 08:08 PM   #2
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
Just measured mine in the driveway: 14" front and back (driver's side)
      10-05-2019, 10:41 PM   #3
kermmmit
Drives: BMW Z4 M
Thanks can you let me know if u have original shocks and spring and how many miles on them? This is my first Z4M , so far I only had E46 M3 And they are set on 14.5"
      10-06-2019, 05:38 PM   #4
Molez93
Molez93's Avatar
35k miles. Stock, unmodified.... Basically it's as BMW shipped it except fluids, filters & tires.
Although, it may be worth me confirming the tires are OE sizes too (they are).
kaybat125.50
      10-07-2019, 09:42 AM   #5
kermmmit
Drives: BMW Z4 M
Thanks
      10-08-2019, 09:41 PM   #6
kermmmit
Drives: BMW Z4 M
Today I lowered mine to 13.5 " looks really good . Nothing crazy low .
      06-17-2021, 11:10 AM   #7
lelandr
Drives: Z4MC, E30M3, E90330i, Z3MC
Does anyone have the specification? Usually, BMWs have a square ride height with the sum of the difference between the measurements to be less than 10mm.
Also, I assume that this is to be measured with a full tank, weight in the seats and trunk, etc.
I measured mine yesterday (M Coupe with original suspension and 86k) in preparation for suspension replacement and conversion to coilovers. It was ~14.5 in the front and 15 in the rear (measurement from rim to fender -9" to be in the middle of the hub).
Thanks!
      06-17-2021, 01:41 PM   #8
maupineda
Drives: E86 Z4MC
These are European cars, as such
Front is 607mm
Rear is 595mm
TIS calls for a 10mm tolerance
Measure from the lower rim lip to the fender sheet metal
