05-13-2019, 03:33 PM | #1 |
Rep 135
Quick Headlight Question
I have the annoying fast-blinking left turn signal going on, along with the lamp out warning light. After a bit of checking, it looks like it's the parking light that's toast (#5 in the attached image). So, not an "important" light but I'd like to get back to normal turn signal blinks.
Anyway, Real OEM takes me to part #15 in this link Which, takes me to this part Instead of spending $35 for the socket assembly, can I just swap out that bulb? If so, is it the bulb from this link (Parking Light Bulb Size: 2825LL) Thanks! -Mike
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i |
05-13-2019, 03:43 PM | #2 |
Rep 2,866
Drives: Anything
Part #15 is for the Halo - the #1 light in your attached picture.
The bulb you want is either #9 or #10 in the RealOEM link |
05-14-2019, 08:33 AM | #3 |
Rep 135
Helpful - thank you!
05-14-2019, 10:01 AM | #4 |
Rep 1,107
Use the screwdriver that is supplied in the small tool kit in the trunk to remove and install the assembly that holds the bulb. There seems to be something special about it (a small dimple on it perhaps) that makes removing and installing the bulb assembly easy. Also, there are two of those bulbs per side, may as well change both at the same time.
05-14-2019, 03:26 PM | #5 |
636
Rep 3,124
That's not the parking light. 5 and 6 are both turn signals.
The bulb you want is #9 in the realoem diagram. #10 bulb is for the parking light. Number 7 in the first post.
05-15-2019, 10:00 AM | #6 |
Rep 135
Thanks for all the help!
I pulled out the bulb last night just to be sure and found the culprit. Time to order the new one.
05-15-2019, 11:13 PM | #7 |
Rep 2,546
That looks like the halo bulb. I believe the turn signal bulb is orange.
05-16-2019, 06:28 AM | #8 | |
Rep 399
Angel eyes bulb #1 is same shape as #5 and #6 only difference is AE bulb 21w and turn signal bulb is 10w, also 5 and 6 as well doing parking light job when turn signal is off, for example in Canada its always ON as soon as you start engine |
05-16-2019, 09:45 AM | #9 |
Rep 135
It was the right bulb - installed last night. #9 in the RealOEM diagram (PN 63217160788), exactly as StickMon described.
05-16-2019, 06:31 PM | #10 | |
Rep 2,546
You're right #5 and #6 are white, I must have been thinking of #7 which is orange. The AE is a 10w halogen. |
