09-20-2020, 01:35 PM | #1 |
Rep 2,051
CTEK MUS 4.3 POLAR trickle charger safe for indoor garage use?
Hi, I have a CTEK MUS 4.3 POLAR charger which I use on my 2015 Porsche 911 Carrera 4S.
Someone told me it is not safe to use this trickle charger indoors (in my garage) on my car for long term winter storage and that it is safe for outdoor use only. Said this is due to the amperage being high (4.3 vs 3.3 on my other CTEK). I always leave it on snowflake winter trickle mode. Anybody know whether this is true or not and the safe way to operate it for long term winter storage? I did e-mail CTEK for comment. |
09-20-2020, 02:26 PM | #2 | |
Rep 24,667
Never got issues in the last 7 years regarding my CTEK in my garage during weekends and entire winters . I highly recommend CTEK
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-20-2020, 03:14 PM | #3 | ||
Rep 2,051
///M Power-Belgium63356.50 |
09-20-2020, 03:43 PM | #4 | |
Rep 24,667
CTEK is also used and sold by BMW . But with a BMW brand sticker on it ... Mate .I'm pretty sure it's just fine
M5Rick60055.00 |
09-20-2020, 04:15 PM | #5 |
Rep 659
Ive had a MUS 4.3 hooked up to my E46 M3 year round for 3+ years now... including subzero MI temperatures and no problems. just make sure you dont hook it up directly to the battery on the E92 M3, use the connections in the engine bay. I also recommend getting the MXS 5, its cheaper and does the same.
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
09-20-2020, 04:38 PM | #6 | |
Rep 1,195
09-21-2020, 06:48 AM | #7 |
Rep 2,051
Thanks. Just realized even the new CTEK chargers are all 4.3 amps even the MXS 5.0. So do think we're good here. The Polar cold edition I have is different in cabling and micro processor for cold weather charging. Max amperage is the same.
What about charging under a closed hood with a car cover on? I've done for three years. There are warnings in the box that say batteries vent gas and proper ventilation is needed... |
09-21-2020, 08:06 AM | #8 |
Rep 1,040
I use 2 CTEK both from main dealers, one from branded BMW for my 635 and one from Porsche for my 911, the Porsche branded one plug into the cigarette lighter, used both for the last 3 years with no problems, they have built in security to cut off of the battery is no good.
09-21-2020, 12:11 PM | #9 |
Rep 2,866
All batteries vent at or near overcharge. If the charger is properly designed, this should be kept to a minimum. Besides, that's what the vent hole and tube is for. Haven't you (we) been charging in a closed "hood" environment all this time since the battery is in a closed trunk?
09-21-2020, 01:23 PM | #10 | |
Rep 2,051
I see lots of people perpetuating old beliefs or myths who never question them or learn new ways. My parents jump a battery direct on the positive/negative terminal; how do I convince them to use the ground terminal for negative connection for example? As per your argument they've ALWAYS done it this way and nothing has gone wrong, right? Therefore by that logic that must be the right way to do it! |
09-23-2020, 01:22 AM | #11 |
Rep 7,484
Left my ctek connected for 4 months when car was laid up over winter. Bought an el cheapo battery monitor and monitored it via Bluetooth once week to check it wasn't over/under charging. Completely safe and better technology than a noco charger.
09-23-2020, 02:31 AM | #12 |
Rep 151
Drives: 2013 M3: E92, ZCP, DCT
Should be absolutely fine even for long-term storage. I use a CTEK MXS 5.0 and found it way better than a Battery Tender, especially for extended long-term (years are no problem). Steps 7 and 8 are magic with it's Pulse and Float Maintenance modes.
-Mike M.
2013 M3 [E92, Alpine White, ZCP, DCT] 2016 i3 REx [Tera World, Capparis White] |
