05-16-2016, 09:01 AM | #1 |
Rep 47
Pocono Raceway - SE Course Option 3 - My Fastest Lap
Hey guys,
Here is some on-board footage from a 2 day HPDE event at Pocono Raceway organized by NASA. I used my iPhone 6 and TrackAddict Pro (RaceRender Free was used to configure the gauges, etc.). Enjoy the video and let me know what you think! Couple of questions: 1) Does anyone know what other peoples lap-times are for this configuration of Pocono? (we ran counter-clockwise) 2) Any tips from any one else who has run this configuration? 3) My brakes started to get hot and mushy at certain points. I'm running everything OEM except brake fluid (Motul 600). I plan on upgrading to Stainless Steel Lines and better Brake Pads. Any suggestions on what are some good options? FYI: I daily drive my car (50 miles commute...) 4) TrackAddict was hooked up to my OBD port via WiFi. I was seeing 140/141mph on my dash whereas TrackAddict was showing 135/136mph. Also, at certain times when I was definitely not touching the brakes, TrackAddict shows brakes being applied (is this data coming from the accelerometer instead of brake input? If so, it makes sense to show me on the brakes when all I'm doing is lifting off the throttle a bit). Any idea on how to get cleaner data? Thanks! |
05-16-2016, 09:28 AM | #2 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Odometer will be off in the higher speeds.
No good dual duty pad. I say get separate track pads if you plan to do this more frequently. Else run Castrol fluids, slightly more aggressive pad and maybe some titanium shims (but really dedicated track pad is the solution). Pocono SE itself has 2 configurations if I recall, and not many run ccw so finding comparable lap times might be tough. Plus it's not a popular road course to begin with. Regarding your inputs from lap timer, I would email the developer. Are you sure it wasn't DSC kicking in? |
05-16-2016, 10:34 AM | #3 | |
Rep 47
DSC kicking in is a fair assumption. As I recall, coming in to Nascar Turn 1 (when I see some brake input, while I was only lifting off the throttle) there was no DSC kick in, but in other places there definitely was. I'll email the developer as per your suggestion. Do you have experience with the Hawk Pads (HP Plus or Street Race)? If so, what do you think? How difficult is it to change brake pads yourself? This is only the second car I've ever owned (never really done much work myself on any car). |
05-16-2016, 10:39 AM | #4 | |
Rep 12,559
