07-19-2017, 02:39 PM | #1 |
Rep 916
Fixed bucket seats and roll bars
This discussion has been driven to the ground all around the internets, but here is my dilemma. Past HPDEs, my body is moving around way too much in the seat. I get soars on my knees and muscles from holding my body in place during cornering. I'm a skinny guy and need better seat support.
Wanted to get some fixed-back bucket seats (and save some weight as well), but the internet says I need to use 5-pt harness, which means I need a harness bar, which means I need a roll cage, and this, and that, and in the end, if you don't do it all, don't do it at all. The theory about bucket seats without a roll bar is that during a roll over, you don't have the reclining seat's ability to "break" and tilt itself, giving your head some room before hitting the roof. On my car in particular, there is NO room for the seat to recline due to the rear bulkhead - thus I don't even think I get the benefit of reclining to save my head. Having said that, wouldn't running fixed bucket seats without a roll bar work just as well (I'm talking rollover concerns, not any other safety concerns such as 3-pt harness use). I've been able to insert stock 3-pt harness through the right side access hole on the Z, thus it can work. Ultimately, I need to find a way to secure myself into the seat better than with these M-seats.
Andre - 2J into a Z4 Coupe!
07-19-2017, 06:05 PM | #2 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.09] |
Good old CG lock?
Or use a reclining race seat but not because of the reclining feature, rather its compatible with factory 3 points and still provides better lateral support |
kaybat125.50 |
07-19-2017, 06:09 PM | #3 |
Rep 11,669
I just went through this.
I'll grab a couple of pics for what I did. Racing seats + 4pt ASB harness + anchor points on bulkhead behind seats.
07-19-2017, 06:09 PM | #4 |
Rep 916
Both good options. If retaining the 3-point system is 'safe' with a fixed back seat, there are options out there, some seats have a slight ingress for allowing the seat buckle to work with the seat. I've also seen short buckle extenders which can then fit through the seat hole.
07-19-2017, 06:29 PM | #5 |
Rep 12,570
Ideally you'd want something like Recaro Sportster but if you're on a budget I'd consider the Corbeau a4's or Sparco R100's
(Note I have no idea how/if they fit our cars) |
07-19-2017, 08:49 PM | #6 |
Rep 11,669
Here's what I ended up doing...
Part of my issue was maintaining OE 3pt in the original location in order to remain street legal (local laws) At the track I remove one bolt to remove the 3pt & connect one half of the 4pt lap I have 4pt ASB harness because I was originally going to try and make the OE seats work. I plan to add the 6pt lower belts next time I have the seats out. The harness bolts through the bulkhead are reinforced both sides and also have a pipe sleeve interior to the bulkhead.
08-02-2017, 02:35 PM | #7 |
Rep 625
inTgr8r if I'm reading this right, you bolted harness points to the bulkhead instead of a harness bar right? I'm in the same position as OP, so interested in the various setups members are running.
Definitely don't like the factory seats, and common notion is that harness bar may as well be accompanied by roll bar. I don't mind half cage as long as I can street drive the car (only to and from track), but wonder if it adds any safety at all? |
08-02-2017, 05:04 PM | #8 |
Rep 11,669
Correct.
The problem with a harness bar is it gets mounted too high (above the bulkhead) for the shoulder straps to be at the proper angle.
08-03-2017, 01:31 PM | #9 |
Rep 625
08-05-2017, 03:58 AM | #11 | |
Rep 758
If anything there's a move to further strengthen the seat backs to ensure they don't break in an accident. The issue with "race seats" and the 3 point belt is the race seat changes the angles of the belt, potentially keeping it from securing you enough when the pretensioner fires. Instead of the shoulder strap catching your shoulder, as it would in the OEM seat, the side bolsters that project forward in the race seat cause the belt to slide down the side of the seat if the belt has just been put on over the outer perimeter of the seat. If you were able to route the OEM belt through one of the holes in the seat for the 4/5 point harness and maintained the OEM angles then it might still work close to as intended. You'll still have the issue of the belt not holding you securely in the seat during normal driving, so the CG Lock is still probably going to be needed. I use one and it works pretty well for at least keeping your butt from sliding around.
Top Down 365
08-05-2017, 04:10 AM | #12 |
1624
Rep 4,296
I have pretty much exactly the same setup as Ian, minus the oem belts. I also have and additional roll bar set into the base of the rear partition. Works perfect, follows the roll hoops (roady) and provides sufficient roll over protection, and isn't in the way like some half cages I've seen (if your a tall guy with restricted movement for aft setting of your seat.)
Rubbish pic, I know, but shows what I mean.
Powered by Last edited by Vanne; 08-05-2017 at 04:18 AM.. |
08-30-2017, 11:35 AM | #13 |
Rep 142
This may be a stupid question, but can the stock seats be modified to accept harnesses? Of course I know that anything can be done with time/money/effort, but has it been done here before and made to look good too?
I'm contemplating going back to a Street class in Autocross (Only my front wheel width upped me to Street Prepared), and the seats have to remain the same as stock, but can be modified for harnesses.
Light a man a fire, you keep him warm for a night. Light a man ON fire,you keep him warm the rest of his life.
08-30-2017, 11:55 AM | #14 | |
Rep 431
http://www.zpost.com/forums/showpost...53&postcount=5
08-30-2017, 12:21 PM | #15 | |
Rep 142
I was thinking more along the lines of someone cutting into the seats to allow the harnesses to pass through.
08-30-2017, 12:37 PM | #16 | |
Rep 11,669
I was looking into this before changing to racing seats, but I couldn't find a vendor for them.
08-31-2017, 07:25 PM | #17 |
Rep 758
You might be able to make the Schroth E36 or E46 clip in harness work. Really depends on your head rest style.
https://www.schrothracing.com/products/quickfit
Top Down 365
