      10-05-2022, 04:29 PM   #1
Vin Man
Drives: 2003 BMW Z4, 2020 BMW 430i
Coding a new transponder key
I purchased a key fob blank and had it cut today. Now I need to get it to start the car and have the key fob lock/unlock the doors.
I've seen a few procedures online regarding programming the fob - along the lines of holding down one button, pressing another 3 times, etc.
But how would I program the car to recognize the key and actully start the car? Do I use NCExpert or Dummy or some other software?
      10-05-2022, 04:30 PM   #2
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
You'll need a coding machine and computer to do it, these use transponders. Not so simple.
      10-05-2022, 04:36 PM   #3
Vin Man
Coding machine is something that attaches to the computer? Cheaper to bring it to dealership?
      10-07-2022, 01:55 PM   #4
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Just to confirm, you do not currently have a working key/fob.
      10-07-2022, 02:02 PM   #5
Vin Man
I have one working key/fob, yes.
I have a second key/fob that has been cut, but not programmed to start the car. It will turn in the ignition, but car does not start.
      10-07-2022, 02:32 PM   #6
elerner61
elerner61's Avatar
157
Here's an older post from the euro Z4 community that has a procedure, then another link that has much more detailed steps for the same procedure.
https://z4-forum.com/forum/viewtopic.php?t=33506
https://www.pacificbmw.com/manufactu...MW%20key%20fob!
      10-07-2022, 02:44 PM   #7
Vin Man
Thank you. These directions are for programming the key fob - the lock, unlock and trunk release buttons. The fob on my second key works as I followed these instructions originally. However, the key still does not start the car.
I believe there is a transponder in the key. The ECU needs to know what the transponder key number is so that the computer will allow the car to start with the second key.
How can I program the ECU to accept the new key when I don't know what the transponder code is? I was hoping there was a way I could connect my computer to the OBD port, but the key in the ignition and tell the computer to add the key.
      10-07-2022, 04:51 PM   #8
Our03z4
This explains about the programmer you need.
      10-07-2022, 05:00 PM   #9
elerner61
elerner61's Avatar
157
Very good to know. I've never read about the keyfob functions (unlock, lock, open trunk) being separately programmed from the ability to link to the ECU and start the vehicle. Good to know....yet it seems DIY ability to code the key to the ECU may make it worth the $200 or so (wild ass guess) it would cost to have someone else do it. Sucks.
      10-07-2022, 05:32 PM   #10
Vin Man
Holy crap. Thanks for the link. Maybe if I take the same meds the narrator is taking, I will be calm enough to dig into one of the circuit boards.
Definitely not a straightforward process as was mentioned in an earlier post.
      10-07-2022, 05:33 PM   #11
Vin Man
Anyone in Gilbert, AZ done this before and want to give it a shot?
      10-07-2022, 07:58 PM   #12
brendanto
brendanto's Avatar
Drives: 2005 BMW Z4 3.0
The AK90+ is not that bad to do other than dismantling the module. I did mine this way a couple of years ago and upgraded to a flip key
      10-14-2022, 01:08 AM   #13
Coi
Drives: 21 X3 M40i, 07 Z4MR
If you can't program it yourself then try calling a mobile locksmith or taking it to an automotive locksmith and ask them if they do it. Tell them what type of car. I've experienced a couple times (my old mazda with active keyless entry/start, and a friend's Infiniti with keyless start) where people on the forums swore only the dealership could program keys but a mobile locksmith was able to easily do it for a fraction of the price. Locksmiths can program for the ignition as well as the doors, especially if you have an existing key.
      10-17-2022, 08:53 AM   #14
Vin Man
I attempted it yesterday. I can't get the device to read my good key. Pretty frustrating but I'm not ready to give up yet.
I am surprised that there is not a way to code directly to one of the ECUs using Expert or Dummy programs.
      10-17-2022, 01:02 PM   #15
Vin Man
This process worked. Did not need the AK90+
https://store.bimmernav.com/blogs/ho...5-e46-x3-z4-z8
