      07-03-2019, 06:09 AM   #1
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Adjustable rear lower control arms
The camber on my rear wheels is not equal, and I've been toying with the idea of getting adjustable rear lower control arms for the longest time.
Any suggested brands? Any cons to using the cheaper ones that cost less than $100? Any real benefits for going with the really expensive ones like Ground Control?
Is it even worth the effort/money?
Look forward to hearing your feedback, thanks!
      07-03-2019, 07:26 AM   #2
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
That doesn't sound quite normal. It should be able to be adjusted within parameters through a normal alignment.
If you aren't lowered or heading to the track looking for more range in your alignment I do not think it's worth it.
Cheaper ones, are made cheaper. You can see it in the construction and welds.
These are the best bang for buck IMHO
ECS Tuning. Search their website for the correct one to fit your Z4.
      07-03-2019, 08:13 AM   #3
pcube
pcube's Avatar
58
Hmm... I was always under the impression that the rear camber is fixed. Only toe can be adjusted for alignment.
Mine's an 07 MC with H&R coils btw.
      07-03-2019, 11:29 AM   #4
3GFX
3GFX's Avatar
I'm not 100% sure but I believe that with the toe some of the camber can be adjusted (although quite limited).
Being that you're lowered and you want the adjust ability I'd say its worth it.
      07-04-2019, 05:03 AM   #5
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Nope, fully adjustable for camber, toe is limited.
Powered by
3GFX722.50
