05-17-2013, 01:22 PM | #23 | |
Rep 1,772
Drives: 2007 Z4M Coupe
05-17-2013, 05:06 PM | #24 |
Rep 12,565
What were you guys listening to though? With a digital hookup, does it really sound that much better? When I listen to Aux I admit it sounds terrible but listening to an iPod with a direct hookup sounds pretty decent in my coupe.
05-17-2013, 11:15 PM | #25 |
Rep 1,772
ipod hook up. same song
08-04-2013, 02:58 PM | #26 |
Rep 2,138
Drives: Me
I now have all side or parking lights disabled on the MC. The ambers do not turn on with the lightswitch in pos 2. All turn signals still work when activated. The Halo still operates in pos1 and pos2.
Using NCSExpert, these were the two functions I had to change to make this work: PIN_20_37_ALS_PO.............Turns off lower amber under the halo SL_VO_ANSTEUERUNG..........Turns off front side amber and rear corner (bumper) lights Depending on your car, you may need to tell the LSZ module its in Europe: LAENDERVARIANTE_LSZ........Country Variant Light Switch US= wert_02, Europe=wert_01 Remember, depending on the variant of your LSZ module, some things will be different. Mine is LSZ-C37. I have changed MANY things on the car in most all of the modules. |
08-04-2013, 04:40 PM | #27 |
Rep 400
Cool, nice work! I guess you just select nicht activ (or whatever the german phrase is) on the first two. Also do you have a power supply you use when programming your modules? I've been afraid of trying stuff out and accidentally frying modules.
08-04-2013, 04:54 PM | #28 |
Rep 2,138
Drives: Me
I hook up a 50amp battery charger in the engine compartment. I worry about depleting the battery on a long session. With the ignition on, my car draws 9amps.
Use the new version of NCSDummy (V.6). It is much better than the older version (.5). Also, any module you want to modify, be sure to make a backup of the original coding file. I just copy and rename the file that NCSExpert pulls from the module (FSW_PSW.TRC) to another directory. I made a backup of ALL the modules on the car before I started screwing around. Remember, CODIERDATEN_LESSEN, reads the data so it is safe... SG_CODIEREN, WRITES the data. Just make sure the FSW_PSW.MAN file has the proper coding in it before you do the SG_CODIEREN. I have no idea what would happen if you sent coding for some other module into the module you are working on, hence the backups... |
08-05-2013, 01:44 PM | #29 | |
Pilot
19
Rep 334
Here is the instruction to turn it on for the european Z4's:
Code:
DRL_BLK_VORN_GEDIMMT nicht_aktiv DRL_BLK_VORNE_2_GEDIMMT aktiv SIDEMARKER_US aktiv DRL_DIMMUNG --- Wert 01 vermutlich ohne Scheinwerfer! wert_03 GEDIMMT_BLK_BEGRENZ_LICHT aktiv BLK_DIMMEN aktiv Set the aktiv to nicht_aktiv and you are ready to go. |
02-06-2021, 08:58 PM | #30 | |
Rep 975
Run halos ONLY as DRL Turn off side markers Turn off dimmed turn indicators when headlamps are on (indicators work as normal) Enable one touch turn signals (set to 5) Activate Rear Fog Lamp Below the settings and what they do Run halos ONLY as DRL DAUERFAHRLICHT_US - DAYTIME RUNNING LIGHTS (USA) from aktiv to nicht_aktiv This disabled the Canada DRL which turns main lights on as soon as the car starts PO_ALS_DRL - POSITION LIGHTS AS DAYTIME RUNNING LIGHTS from aktiv to nicht_aktiv This disabled the postion lights (front and rear) as DRL, in combination with the above Canda cars run all lights on ALL the time Turn off side markers SL_VO_ANSTEUERUNG - FRONT STANDING LIGHTS CONTROL from aktiv to nicht_aktiv This turns the front and rear side markers Turn off dimmed turn indicators when headlamps are on (indicators work as normal) PIN_20_37_ALS_PO from aktiv to nicht_aktiv This turns the inner amber indicator bulb off (the one below the inner lens) SIDEMARKER_US - USA SIDE MARKER LIGHTS from aktiv to nicht_aktiv This turns the outer amber indicator bulb off (the one below the xenon lens) Activate Rear Fog Lamp PIN_20_ALS_NSL - OUTPUT PIN 20 AS REAR FOG LIGHTS from nicht_aktiv to aktiv This activates rear fog lamp, but you need the Euro switch, otherwise you dont have a button to activate the rea fog. Enable one touch turn signals (set to 5) CYCL_TI_BLK - ONE-TOUCH TURN SIGNAL FUNCTIONALITY from einmal to funfmal This makes the turn indicators to blink 5 times with a light touch of the indicator stalk I also enabled brake force display so the center del stop light bar blinks under heavy braking or when the ABS engages. |
AK72286.00 |
