05-14-2020, 10:56 PM | #1 |
Rep 6
Wiper Well Drain; Missing Part?
Hi, I could use some help identifying a part. Beneath the wiper scuttle on the left side is a cavity for water to collect and drain. My LHD Z4 2006 simply has a hole in the metal about one inch in diameter and the water drains directly into the engine compartment. There's no duct/plumbing to direct the water to the bottom of the engine compartment. I've checked with a few BMW dealers and they were useless. If you have an E85 I would appreciate if you would check your car and let me know if something inserts in the hole and directs the water properly. For reference, the hole is directly behind the Positive jumper terminal. You should be able to easily feel the drain hole (or some part attached to it) without removing anything e.g. the scuttle. The digram shows parts 8 and 9 and I think those might be the drain. BMW calls those parts a condensation drain and the BMW parts guys guessed that was for the air conditioner. Unfortunately it's a pricy special order (not returnable) and I want to get it right. Thanks for checking, I appreciate the help.
05-15-2020, 10:23 AM | #2 |
Rep 406
There is a rubber "flapper" style drain cover that fits in that hole...
Tried to find it in realoem.com as well as I know what it looks like... but couldn't find it. Mine is still inserted in the hole... but it's a debris trap like the drain plug on the convertible top well drains that lead to the top motor being "drowned". It looks like a short plumbing fixture 90 degree connection joint.... appropriately sized for the drain hole. It has a flapper valve that allows water to drain out. Mine was filled with crap effectively blocking it... not surprisingly given where it receives the drainage water from. There is absolutely no downside to not replacing it... as the water drains down the front of the firewall/bulwark even if fitted....
Sent from my smart phone...
05-15-2020, 12:24 PM | #3 |
Rep 6
Thank you Clearancediver, I appreciate your feedback. I thought someone might have removed the part for the reason you mentioned - it gets clogged up. I'm going to try going without the part. Hopefully at freeway speed, wind won't channel up the hole and push water into other areas under the scuttle. The issue I had (just bought the car) was water drained out the wiper drain hole, down the firewall and into the hole intended for the Sound Generator. The left side of car filled with water after weeks of rain. My engine model (N52) did not come with the Sound Generator (tube that passes engine roar into the interior through the firewall). Without the Sound Generator, the associated hole in the firewall normally has a rubber plug (referred to by BMW as a Blind Plug). Mine was missing that plug. Of course, I investigated all the common water intrusion issues only to find the wipe drain directing water through the firewall and into the car. I'm still shaking my head. Thanks again.
05-15-2020, 02:16 PM | #4 | |
Retired
96
Rep 174
Item no. 8? |
05-15-2020, 02:16 PM | #5 |
Rep 406
I've an '04 with the sound tube... so didn't have that problem.
Blanking plugs are inserted for a reason as you found out. That issue would never have come up in my thought process.... as mine was "plugged".
05-15-2020, 02:31 PM | #6 |
Rep 406
I think the part you are looking for is...:
51717018221 Water drain, left From:09/02/2002To:-Weight:0.047 kgPrice:$8.97
05-15-2020, 07:20 PM | #8 |
Retired
96
Rep 174
Just went out to the garage and looked my 2006 E85 M
By feeling aft of the positive jumper lug and up under the windshield cowl I was able to find the opening you described. No drain tube on my vehicle, just an open orifice as in your photo. I have found the part number that corresponds to items number 8 & 9 in your diagram. Number 8: 64116916761 Available several online suppliers, like Turner Motorsport for under $15. https://www.turnermotorsport.com/p-1...uine-bmw-part/ Number 9: 64116915666 Available several online suppliers, like Turner Motorsport for under $10. https://www.turnermotorsport.com/p-1...uine-bmw-part/ |
05-16-2020, 02:44 PM | #10 |
Rep 6
Thanks Emmrbee and Clearancediver, awesome feedback - great community. My guess is if Emmrbee's car is also missing the part, at some point, it was removed intentionally. Maybe that's a work-around to avoid clogging. I'm thinking of leaving the drain off (let it drain out the hole). If I install the drain, I'm not too keen on cleaning the part should it get clogged down the road. In the process of removing the scuttle, I broke two fastener stays (plastic-welded to the scuttle). I glued them back but I'm not sure if they, or the other fastener stays, would handle another removal of the scuttle. I appreciate the help. Be well.
05-18-2020, 08:47 AM | #11 | |
Rep 305
And then I remembered this post.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list) 2015 335i GT 2014 981 Cayman S manual |
wdb4721.50 |
