05-13-2020, 07:47 AM | #1 |
Rep 19
Airbag light on, code not showing up on Scanner
Recently I replaced the lock actuator on my drivers side door. Before starting I unhooked the battery because I knew I'd be disconnecting the airbag in the door. Halfway through the project I realized the window needed to go up so I could gain access to the actuator. Without thinking I reconnected the battery to raise the window. Needless to say, when I eventually started the car the airbag light was on.
I ordered the C110 scanner after reading that would let me clear the code. To make a long story short, it's not showing an airbag fault. Does anyone have any suggestions?
chrispiascik.com
05-14-2020, 03:25 PM | #2 |
Rep 279
I just went through this. I removed my seats to clean the carpet underneath only to find an airbag light that wouldn't go away. I went through all the menus that made sense and hit erase code. Nothing. Bought Carly for BMW and nothing. The other day I took another shot at it with the Creator scanner. I recommend you go through every single option in the CHASSIS and BODY sub-menus and clear them all. Even if it says there is no code and they are not related to airbags. I wish I wrote down which unit I cleared but eventually it revealed two codes: "SEAT-BELT BUCKLE; OPEN CIRCUIT and OPEN CIRCUIT; FIRING CIRCUIT, BELT TENSIONER, FRONT RIGHT"
I hit clear and poof! light was gone. So clear every single option you can and I hope you get the same result. Let us know if it works! |
05-14-2020, 10:31 PM | #3 |
Rep 2,542
Have you tried INPA?
05-16-2020, 08:21 AM | #4 | ||
Rep 19
chrispiascik.com
05-16-2020, 08:22 AM | #5 |
Rep 19
No, I'm not familiar with that. I'll do some research.
chrispiascik.com
05-21-2020, 11:34 PM | #6 | ||||||
Rep 19
chrispiascik.com
05-22-2020, 01:20 AM | #7 |
1621
Rep 4,294
Great!, so it was the same issue as Sterling?
Maybe add that to the DIY sub group guys .
Powered by |
05-23-2020, 10:18 AM | #8 |
Rep 279
05-23-2020, 10:53 AM | #9 |
Rep 405
Most hand held scanners have difficulty reading BMW proprietary codes.... which is why I eventually (actually fairly soon after buying the car) acquired INPA.
The first code I ever got was the same B pillar/seat belt code as diagnosed by an independent using his handheld scanner. That wasn't the issue though. Turned out when a BMW tech actually used BMW software to read the error code it was a SRS low voltage code. Cleaning a connection in the battery well (terminal block....B+ connection to BST) solved that issue. I've had a distrust of handheld scanners since....
Sent from my smart phone...
