      07-27-2007, 12:53 PM   #1
Gel
Drives: Z4
Lighting Wiring
Ok, so i swapped my 04 xenon lights over with 07 xenons
In doing so I lose the 55w H7 bulb and it changes to a 5w sidelight lol
This still comes on as it shuld but I as it is so weak I lose my high beam flash.
Not only that sometimes when the high beam is on the bulb fault light comes on until I switch off the ignition, but sometimes it goes off again.
Is this fault due to incorrect resistance from the bulb?
If so, could wiring up a set of fog lights cure this?
If so, can I connect it to my existing fog lights...my concern being if my high beam is on and then I put my fogs on won't that short something out?
http://www.youtube.com/watch?v=BMQH_xrFmKU
Z4 2.2 Remapped, Cold Air Induction, Sound Generator
      07-27-2007, 01:30 PM   #2
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
The general consensus is to NOT swap older generation headlights (03-05) for newer headlights (06+) as the wiring is quite different.
      07-27-2007, 08:44 PM   #3
Gel
Drives: Z4
You say that but everything works as it should apart from the bulb fault light and lack of high beam flash.
I still have high beam just only when I push the light stalk forward.
Same number of bulbs, fits perfectly and they look great...just want to iron out these two problems...the buld out fault being the main one.
      08-03-2007, 03:57 PM   #4
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
The wiring inside the housing is different. It's been done before, but the it was generally said that it was a royal pain to redo the wiring inside the light housings to make it work.
