      07-31-2019, 02:52 PM   #1
Residentj3553
Residentj3553's Avatar
Drives: 2008 BMW Z4M Roadster
S54 Rebuild Issues
Hey all,
I recently rebuilt my top end of my Z4M (including VANOS) and I'm experiencing an issue.
Started the car fine and it idled smooth. Took it outside my neighborhood in low RPM and it feels a bit sluggish and hesitant but the minute I give it aggressive throttle it goes into limp mode and throws me the code P1644 and P1554
Clearing the codes only gives me P1554 until I push it into limp mode again... then P1644 shows up again.
Gonna double check my Cam timing but wanted to get all of your opinions so I know what to look for when I open it up again. Maybe someone had this happen before? Any advice appreciated!
Thanks!
2008 E85 ///MZ4 Roadster - Sapphire Metallic Black / Imola Red Int.
IG: Jessed.alvarado
Mods: ProFlex E85 Flexfuel kit, Eventuri Carbon Intake w/ RPI scoop, Megan Headers, Custom Axle-back exhaust, KW V3 Coilovers, Stoptech ST40 BBK, Poly FCABs, APEX PS-7s, Diode Dynamics Headlights, CF Trunk Spoiler, Sideskirts & Diffuser.
      07-31-2019, 06:40 PM   #2
Michael9218
Drives: 2007 Z4 M Coupe
When you timed the cams, how did you make sure the vanos pistons were fully retracted?
The Biesan procedure doesn't mention this, but just pulling on the cams to push the pistons didn't get them all the way in for me. My car ran fine but eventually threw a cam timing code (no limp mode). I cracked it open to check and both were about 6 degrees retarded.
The way it was explained to me is that the pistons have some air pressure in them after you do the full rebuild. One should loosen the piston caps and allow air to escape when you do the initial cam timing. Also us the OEM timing tool. The various cheap ones are sloppy and can also give inaccurate results.
      07-31-2019, 07:15 PM   #3
Residentj3553
Definitely didn’t know about the piston caps! Thank you, and yeah I’ll double check the timing.
      08-01-2019, 09:37 PM   #4
Residentj3553
You are absolutely right! My exhaust piston was not fully in and exhaust cam was a bit off. Will report back when valve cover is put back on.
Thanks a ton michael.
IG: Jessed.alvarado
      08-02-2019, 12:25 AM   #5
Residentj3553
Put the car back together after noticing the exhaust cam was a bit off.
But the same code came back immediately. P1554
So the exhaust cam is probably unaligned again...
I’m putting the splines in the first available slot rotating and using the alignment bridge but the exhaust cam keeps getting unaligned?
I even rotate the assembly by hand a couple of rotations and the cams are fine before assembling the valve cover. But the minute I turn the car on the code comes back and my cam is off.
I must be missing something.
Do the pistons need to be fully inserted into the vanos before rotating the splines into the cams? Or vice versa?
I don’t understand why the intake cam seems fine though if I’m doing it wrong.
Any more advice?
Thanks!
      08-02-2019, 02:32 PM   #6
Michael9218
Well, it's very odd that the intake cam was not also out of alignment. Something else is amiss. Finding the optimal spline gear will give max cam advance when Vanos is fully engaged, but I don't believe it will affect cam alignment.
Assuming you're using the Beisan kit and procedure, I would say read back through it and see if you omitted a step or misunderstood a step. If you still can't figure it out, call Beisan. I've talked to him before and he's very willing to give advise.
      08-03-2019, 02:08 AM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Here's how I did mine, but I can only vouch for the exhaust if you're using a C300 hub.
Keep in mind it's a closed-loop system that will "adapt" as long as you're within ±10°.
If you're just a few degrees off and you get a code, something else is wrong.
      08-05-2019, 01:38 PM   #8
Residentj3553
Are you sure it's within ±10°?
Update: I went and bought a much better OBD II reader and was given the 2A98 code for cam to crankshaft correlation and a code for a throttle actuator error which probably explains the limp mode.
Talking to Raj over at Beisan Systems. Very, VERY kind and Informative guy. He explained that the exhaust cam actually advances after every shutoff so the cam not being lined up after starting the car is normal and nothing to worry about... instead he says the code is for the intake cam so I redid the process AGAIN and sure enough my intake cam was the one not lined up correctly. He walked me through how to adjust the cams without removing Vanos completely and put it back together. Drove it around all night. No codes came up!
The next morning I start up and the same code comes back and car doesn't run as smooth.
Gonna give it another go and remove the Vanos this time and take my time with the timing. Very strange.
IG: Jessed.alvarado
      08-05-2019, 04:22 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by Residentj3553 View Post
Are you sure it's within ±10°?...
Pretty much. If you look at the picture from INPA in my first post in the other thread, the green zone is ±10°.
Not that it's definitive proof, but I can attest to being 14° off on my exhaust after an indie "mechanic" worked on it, and the car still ran fine.
I was blissfully ignorant until I got INPA running.
Edit:
Found my original INPA measurement. This actually ran fine with no codes, but took several turns to start, since the range was restricted and it couldn't get the exhaust camshaft where it wanted to be for optimum starting.
      08-05-2019, 04:42 PM   #10
Residentj3553
Edit:
If 10 degrees is the tolerance then it might be the fact that I swapped low mileage cams in.
My intake cam might be warped or damaged? Anyone have any experience with 2A98 code?
IG: Jessed.alvarado
      08-07-2019, 08:20 AM   #11
Michael9218
This statement tells me you're not following the procedure. It is VERY clear in the procedure that you must pull the cam to full retard before you check the alignment and when aligning. Go back through the procedure and see what other steps you omitted.
      08-07-2019, 08:40 AM   #12
Residentj3553
I swear i'm doing twice the work because i'm rushing everything.
Will report when I find the fix.
Code is still there and my intake is still lined up after.
IG: Jessed.alvarado
      09-17-2019, 11:59 AM   #13
Residentj3553
So update...
I couldn’t figure out the problem myself so I took the Z to Ghery at the very reputable Garage 54 shop here in the Los Angeles area. Ghery works on the S54 multiple times a week and owns an 850hp Z3M. Very honest and friendly guy.
He took apart the vanos and gave it a good polish... had to swap the seals of the pistons. The lack of pressure wasn’t allowing the vanos to adjust for rpm which was causing the hesitation and limp mode.
But after start up, the hesitation and limp mode is gone but the correlation code is still present.
Intake to crank timing code upon wide open throttle.
He’s swapped cam intake sensor, crank sensor, tore down my vanos a second time to see if he missed anything but still isn’t sure what is causing the problem.
At this point I’m really thinking it’s the used cam since there’s no where else to look? He’s swapping the intake cam this week as a final guess...
wondering what anyone’s thoughts are on the potential problem?
      09-26-2019, 11:23 AM   #14
Residentj3553
Solution
Update: Swapping the intake cam fixed the car! Extremely rare but it worked. The intake cam was faulty somehow... visually looked great and synchro gear looked good too. (was even swapped out to test)
What a pain... Just in case any has this problem in the future.
IG: Jessed.alvarado
      09-26-2019, 05:19 PM   #15
racerbruce
Racerbruce
racerbruce's Avatar
1195
Drives: 2007 Z4MR Imola Red
Great news!
Congrats!
This must have been painful and expensive; any visual or tolerance measurements that provide a reason why the cam was defective??
Racerbruce
OZ Rims / Bilstein B8 Struts & Shocks / Eibach Pro-Kit Springs / ZHP Control Arms / RE Diablo Exhaust / RPi Air Intake / BMC Air Filter / CDV / RE Trans Mounts / 3M Paint Protection / TMS CF Grilles / TK CF Mirrors / Skyer CF Spoiler / CF Antenna / M Pedals & Dead Pedal / CoCo Floor Mats / WeissLicht LED Rear Turn Signal Lamps / #748 of 3,041
      09-29-2019, 04:49 PM   #16
Vanne
Vanne's Avatar
United Arab Emirates
1030
Drives: 2007 Z4MC
Thanks for sharing, these kind of things can be extremely frustrating. Glad you got it sorted in the end. I gotta ask, why did you swap in a different cam set? (Assuming they were the same setup as before?)
      09-30-2019, 12:13 PM   #17
Residentj3553
Originally Posted by racerbruce View Post
Congrats!
Visually they look exactly the same!
I havent put them both on V blocks to see actual measurements but im guessing they wont be the same down to .001 of an inch.
IG: Jessed.alvarado
      09-30-2019, 06:48 PM   #18
Residentj3553
Same setup. Long story short I trusted the dealership when they said valve clearance was performed already
Continued to drive the car until I started hearing funky clicking noises coming from the motor and coolant disappearing...
Had to tear down the engine to find the clearances off by almost .050 in some points and extreme wear due to coolant in the oil I'm assuming.
So I had to get a head gasket and swap rocker arms and cams.
Bought used cams to save money from a used S54 and those turned out to be faulty as well.
Lesson learned. Don't trust dealerships and buy new for less of a headache.
P.S. The amount of wear on the rocker arms and cams was insane... rocker arms were actually inverted due to wear...
Would bad clearances accelerate the wear? Anyone savvy in that department?
IG: Jessed.alvarado
Vanne1030.00
      02-04-2020, 08:40 AM   #19
Residentj3553
Another update: So the code ended up coming BACK after driving a bit. I'm sure you guys know how happy I must've been.
The real problem ended up being the Cam Sensor wire being pinched sometime during the rebuild. No faulty cams at all...
IG: Jessed.alvarado
      02-04-2020, 10:34 AM   #20
Vanne
Vanne's Avatar
1030
Drives: 2007 Z4MC
holy crap mate.. thanks for sharing though, hopefully it will help someone else.. wow, sometimes trying to find the issue is soo bloody difficult.. mate, glad you finally found the drama..
2007 EuroSpec Z4///MC DIY Arial. Carma FF race exhaust. Cust. D///MK 6 Speed ultra SSK. CDV X. CSL 19" Rims. Apex 75mm kit. Stoptech brake lines. APR Aero. CSL intake. Epic Alpha-N. KW CS. SS sec1. 288/280. ECS power pulleys. Tillet B6Fxl. Sabelt.Varis. Brembo GT. ME STB. JB/Sachs Race SMFW .
      02-05-2020, 09:45 AM   #21
Residentj3553
It's been a nightmare trying to figure out. Posting all of this in case someone needs this in the future.
IG: Jessed.alvarado
