11-01-2018, 02:36 PM | #1 |
Commander
219
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
S54 Maintenance
Some S54 maintenance happening.
Car is currently at 149000km (92000 miles) VANOS gear bolts being updated: VANOS Exhaust hub wear (VIDEO) I had my exhaust hub and Oil pump disc sent out together to a local shop to have it redrilled. You can see in the video how much play it had developed over time. Rod bearings: Not in the greatest shape when they came out, if you're on the fence about doing your bearings, hopefully this will help
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
11-01-2018, 06:49 PM | #3 |
Rep 2,051
Thanks for the update. How do we know exactly when all these things need to be done? Is it guesswork, are there preliminary signs or do these areas need to inspected periodically? When it comes to VANOS, bolts, timing chain guide, etc I'm not sure what to do and when and it drives me nuts. Like worrying about a ticking time bomb.
11-01-2018, 07:04 PM | #4 |
10625
Rep 4,848
Those bearings arent a moment to soon; normal advice is to do them every 50k miles (80k km); at least among the european/german specialists.
Did you also replace the control valve piston in the oil pump? That is also a wear item on the s54, and is usually also replaced (at least in germany; there you can get specially coated ones):
11-01-2018, 07:07 PM | #5 | |
Rep 2,051
11-02-2018, 01:35 PM | #6 | |
Commander
219
Rep 850
I have not heard of this part before, nor anyone replacing one. Do you have a part#?
11-02-2018, 02:23 PM | #7 |
10625
Rep 4,848
I dont think bmw gives a part# for this part for the s54.
I've seen the parts somewhere on facebook from a german tuner/shop. Maybe the m54 version fits I dont know (bmw lists this part for m54 but not for s54) Browse the german M3/z4m forums. The germans are quite a step ahead in maintenance and dealing with s54 problems compared to the US crowd. There are multiple topics on the german m3 forum and z4m forum (all my pics come from german topics), over there this is a common way to deal with this problem. Even this newsarticle in Auto Motor und Sport speaks of it (it addresses what issues to expect on an e46m3, thus also s54) https://www.auto-motor-und-sport.de/...rprobleme-smg/ This article even hints on that there might be a relation between the wear on this part and the wear on the rodbearings (I dont know if thats really true, but I also dont know if anyone really monitors oil pressure on s54's in the right place)
