      08-28-2020, 08:16 AM   #1
nadaclue
Drives: Urban Green 2003 3.0
AC / heat issue
Hello everyone,
I'm hoping someone might have some insight since I haven't found any decent leads/answers.
I took my '03 3.0i in for a non-functioning AC that would only blow hot. The independent shop found it was the compressor and replaced it, no problem. However, even though it was properly circulating through the AC system, it wasn't blowing cold air.
So the shop did some trouble shooting and have found that the heater box under the dash isn't working properly so it blows heat and AC at the same time. They blocked off the heater core and right now the AC works without issue.
That brings me to my question, does anyone have any idea how the heat/AC box works at diverting airflow from one to the other? When I look on RealOEM, there are solenoids that appear to operate airflaps. Am I going to have to rip out the whole dash to get to this thing to figure out what's going on? First I'll check the obvious like fuses, but I'm really hoping I don't have to pull the dash!
https://www.realoem.com/bmw/enUS/sho...diagId=64_1281
      08-28-2020, 01:45 PM   #2
zgood4u
Drives: 06 Z4MC BSM
I had this exact thing happen to me about a month ago. My mechanic took a look at the box and determined (forgive my lack of knowledge as I'm paraphrasing) there are tabs on that box that control the flow had broken. He saved me a ton of money by epoxying the tabs back. So far so good.
