      12-03-2019, 08:24 AM   #419
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Yeah those bushes are similar, his bring the sub up 10-11mm... or so apperently.
All great points Micheal.. I am not sure as what to comment yet mate, i would like to get my nose on the car first and then get the wheels on and see where we sit. I am not adverse to a little fabrication (i have a great race shop) but obviously the less cutting the better, however i guess ill see whats what when the car actually sits on the ground. Anything before that is pure speculation. I just need the car to sit semi flush and for the rear suspension to be able to operate properly.
Powered by
      12-04-2019, 04:03 AM   #420
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Powered "press to fold up" mirror's.. 6.6lbs.
      12-04-2019, 11:47 AM   #421
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Replaced by these
wdb4732.00
      12-04-2019, 12:01 PM   #422
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
MPC Motorsport rear upper control arms.
      12-04-2019, 03:10 PM   #423
2skiddy
Drives: Z4M Coupe
Sexy arms, I modified some Eibachs, as that's all that seemed worthwhile at the time, what make are these?
      12-04-2019, 10:24 PM   #424
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
These are steel units from MPC Motorsports. I wanted the billit ones, but was advised against it, unless going for a straighht arm. These are steel, so will be heavier duty than the bent billit ones. They will keep me having to notch the frame down by 15mm. which doesnt sound much, but its a lot.
Powered by
      12-05-2019, 02:16 AM   #425
2skiddy
Drives: Z4M Coupe
I think you have chosen well, design looks more simple, the VLN ones are tubular steel with rod ends BTW. I suppose the notching of the chassis rail depends on your diff mounting height/ride height, it IS needed on mine for the articulation.
Keep up the good work!
      12-05-2019, 02:41 AM   #426
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks Skiddy,
Was great to get home yesterday from BKK. 2 days off and spent today wrestling with the nose/splitter piece. (It's a one piece being wired up for quick disconnect as the car will be so low it will eat any speed bump/bump in the road. Also to get the car on a trailer/flat bed, the nose will need to come off. I figure 5 minutes work to get the nose on or off should qualify as quick disconnect in my book lol.
Today's job.. put the nose on...
Great success!!
3GFX722.50
      12-05-2019, 03:23 AM   #427
2skiddy
Drives: Z4M Coupe
Looking good Vanne, I bet you are feeling excited, I remember, just, I was!
Quick release front will be a bonus, I wanted to go that route initially, but with all the parts that marry up to the factory nose, arch liners, brake ducts, etc, it was going to mean lots of mods to the carbon panels. Yes it could be done, but thinking ahead for the next owner(s), it was left as standard. So if you can do that, great, as it is a bit tight getting onto the trailer. The down side is that the nose is just massive to carry separately!!!
Vanne1620.50
      12-05-2019, 03:52 PM   #428
2skiddy
Drives: Z4M Coupe
Are you moving the engine and box rearwards with the conversion? Michael has done it IIRC, I had no choice due to the vents in the bonnet and ARB positioning.
Vanne1620.50
      12-05-2019, 10:58 PM   #429
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
No plans as such at this stage mate. Hopefully haven't bitten off more than I can chew already and I wanna get some seat time in before the season closes. As it is, so many changes and upgrades to the chassis, that I have zero idea how this car is gonna Handel when I finally do get it back on the track. Testing hopefully in mid Jan, depending on how my race shop goes with the pending barrage of kits and parts... Gonna be interesting on how that goes and has me slightly worried... Actually has me a LOT worried ..
Need to fab me some brackets today.
      12-06-2019, 12:33 AM   #430
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sourced the quick disconnect ratchets for the rear bottom of the splitter.
To be slightly modded ofcourse. x 3.
longress104.50
      12-06-2019, 03:27 AM   #431
2skiddy
Drives: Z4M Coupe
They're different! Are these going to be mounted near the ARB mounts? The nose mounts directly to my heavily modified, by BMW, ARB mounts. Actually the bearing carrier, the ARB is massive!!!
      12-06-2019, 06:31 AM   #432
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
No, this splitter comes much further back. It's going to mount where the old underside cover used to mount.
Hopefully this pic will help.
And quick and dirty sketch.
Powered by
3GFX722.50
wdb4732.00
      12-06-2019, 01:45 PM   #433
2skiddy
Drives: Z4M Coupe
That's where it should come to BTW, it's a copy of the BMW one.
      12-06-2019, 08:34 PM   #434
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
awesome, have you got any pics on how yours is mounted back there?
no need to rfe-invent the wheel then
Powered by
      12-07-2019, 03:50 AM   #435
2skiddy
Drives: Z4M Coupe
Photos on my project posting Vanne, hope it makes sense how it is mounted?
      12-07-2019, 08:01 AM   #436
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks Skiddy, I'll take a look.
Today's effort.
Powered by
      12-08-2019, 09:38 AM   #437
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
So today the HVAC was slated for removal.. but as per Murphy's law, let's weld in the cross bar and make it part of the roll cage...
And as you can probably see from the pics, the blower/HVAC box is *behind* the cross bar. DOH!!!!
Yep, you might see that the HVAC box isn't supposed to look like that...
Detective like eyes might see bits of the HVAC box all over the foot Wels.. lol..
Powered by
wdb4732.00
      12-08-2019, 11:05 AM   #438
wdb
dances with roads
wdb's Avatar
4732
Hey. Out is out.
Vanne1620.50
      12-09-2019, 12:34 AM   #439
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
thats what I tell my Missus all the time too.
Powered by
wdb4732.00
      12-09-2019, 01:20 AM   #440
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Bought s floor foot rest for when the car is back together.
Powered by
