05-22-2019, 10:01 AM | #1 |
Rep 3
Sticky Column
Hello All,
This is my first post. Please forgive me if this thread as already been beaten to death. I'm looking to purchase an inexpensive sports car, and the BMW Z4 seems to fit what I'm looking for in one. I've been looking at 2003 to 2004 year models since to seem to fall into the price range that I can afford. however, now I'm reading about the engineering problem with the steering columns in these year models. I've test driven a couple of these year models (a 2003 2.5 and a 2004 3.0) before I heard about this problem. Didn't notice this issue in either, however, from what I've been reading the sticky column problem doesn't show up until after the car has warmed up for about a half hour or so, or on a really hot day. Since this would be strictly a summer car up here in the Northeast, this is a major concern. I'm guessing that since this is an engineering defect then all these Z4 model years would be affected with this problem. The fix, so I've been reading, is to have the column replaced to the tune of about $3800. So, here's my questions: 1. If one was to go for the $3800 column replacement, would that be a newly engineered column, minus the old defect? 2. Would I be better off adding that $3800 to my purchase budget and buy a latter model year that doesn't have the column defect? If that's the answer, then does anyone know which Z4 model year did BMW start putting in the corrected columns? Thanks in advance, Manual Shifter |
05-25-2019, 06:03 PM | #2 |
Rep 166
I was able to fix mine by adjusting the small 'collar' on the column from the drivers side footwell.
Mine was REALLY bad and I was able to dial it out almost 100%. I also drilled a hole and added more grease inside. From what I've researched, its an issue with the OEM grease breaking down, and also the worm gear swelling when it gets hot. Being that I live in Atlanta, we have many hot days, many many more than N.E., and it really only got intolerable in 90+ degree days. If everything else on the car was what you wanted, I wouldnt rule it out for this issue, with the understanding that you may need to do some 'shadetree' work on it. |
wdb4718.00 |
05-26-2019, 12:54 PM | #3 | |
Rep 1,247
Same here. Had my 04 for about 5-6 year now and this year if the first time I have had it show up. I Googled it and did the collar adjustment and it seem 100% gone. It is not a hard adjustment, but is tedious and took some patients and thinking outside the box to get to the screws. Access was the only issue, would have been 30 min fix if you could get to the screws. Still a super easy fix compared to a $4k column replacement that will have the same issues in time. Don't sweat it.
05-26-2019, 03:40 PM | #4 |
Rep 685
Have a 03 2.5 roadster for cheap if you want. I just upgraded to a 08 3.0si coupe so I don't need it anymore...so says the wife. Haha. No steering issues in the 08 model but the 03 does when hot. My 03 is a solid little car, that year is very easy to work on, lot less electrical sensors and such. And you can actually check the fluids unlike the 08 model. The 2.5 has plenty of power honestly and the sport mode makes it feel peppy, especially with the 5sp. The 3.0si is a whole different animal.
05-28-2019, 09:46 PM | #5 |
Rep 3
Sticky Column
Hello All,
Thanks for your useful responses. Sounds like you figured out a workable solution. Sure beats installing an expensive new column, which would just have the same engineering defect as the one it would be replacing. I had started to think maybe these cars were a bad choice just for this specific problem, but maybe now I'll revisit looking at Z4s, or possibly a less expensive Z3 in decent shape. Would really like to get a nice little manual shift sports car for the summer for my wife and I to drive. |
05-28-2019, 09:52 PM | #6 | |
Rep 685
05-29-2019, 09:19 AM | #7 | |
Rep 1,247
Cons are - not a comfortable car for long drives (to me anyway) and only 2 seats, but then that is not why I bought it - so not a huge problem. Would not want it as my ONLY car, but goes well with my SUV DD.
06-01-2019, 08:36 AM | #8 | |
Rep 18,724
Now the E85/86 (roadster/ coupe) is a completely differently built automobile (out of the same factory a decade later). The build quality of the E85/86 Z4 is exemplary and night and day different than a Z3. For a few thousand more, just get a 2006 and up Z4 with the N52. A friend of mine has a 2007 Roadster. I just drove it for the first time last weekend, and it is way better than a Z3. My 2 cents.
