05-22-2019, 07:21 PM | #375 | |
Rep 14,522
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
05-22-2019, 07:38 PM | #376 | |
Rep 4,819
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
05-22-2019, 08:41 PM | #377 |
Rep 12,722
I'm going to pick one of these systems up. All the reviews look good.
Instagram; @roastbeefmike
RickFLM410954.50 awilki0101518.50 |
05-22-2019, 08:49 PM | #378 | |
Rep 1,543
I ordered a bag of Hyr-Brix fertilizier that Pete from GCI has been raving about. Bags aren't badley priced and you can reduce the drop rate to lay less N but...holy crap....shipping was $22. I found something at a local nursery that had a curious lable on it. Almost seems like a custom blend containing Mess, XRT, & Milo and I can't find anything online. |
lsturbointeg9152.50 |
05-22-2019, 09:42 PM | #379 |
Rep 1,014
Check out b-hyve, i had my system done last year and my landscaper installed it to automate everything. I have 7 Zones and it has a great app, you can allow it be ‘smart’ or you can define custom programs...it cool to be able to control your usage anywhere you are online.
05-22-2019, 09:50 PM | #380 |
Rep 12,722
I actually just got it on the way home. Cost $120 at Home Depot, and my water district offers an $80 rebate. I'm super happy about that. I won't have time to install it until next week though.
RickFLM410954.50 |
05-23-2019, 05:51 AM | #381 |
Rep 4,819
Let us know how it works out. We have a well for irrigation so we are not on city water but somewhat interested in one of these to optimize watering and adjusting programs more easily from an app. So app reliability and functionality would also be important, including just turning on and not following programs when I want to run irrigation in one or more zones (for example after fertilizing). We have a mechanical dial timer with an off / off / timed on toggle switch that is super easy to use outside and works fine for the basics but it could be a little more advanced.
05-23-2019, 06:18 AM | #382 | |
Rep 2,038
Drives: 2022 X6///M Comp
Ideally, I'd like to plant arborvitae, not only to cover the fence and have some green but so they will grow high and give me some privacy. I have about 5 feet from the pool edge to fence line. When the pool is covered, I have less than that, and need more room for the straps and anchors for the pool cover. If I was completely out of my mind, I would shorten the pool. It's pretty long and runs the length of the property. Not sure why they didn't do it across the width.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
05-23-2019, 07:31 AM | #383 | |
Rep 14,522
bosstones1154.00 |
05-23-2019, 07:58 AM | #384 |
Rep 4,819
I did some spot weed spraying last weekend with RTU RoundUp for Lawns and I have to say it works pretty well. I didn’t broadcast - only spot sprayed weeds I could see, including 2 small patches of crab grass in different spots. I noticed everything dying / dead when I took the dog out this morning, with minimal yellowing of grass around the weeds. I do wish the sprayer with the RTU bottle worked a little better but it is manageable.
05-23-2019, 09:08 AM | #385 |
Rep 308
05-23-2019, 09:37 AM | #386 |
Monkey Marshall
623
Rep 218
flowers I planted from seed are beginning to bloom
wrickem2101.00 lsturbointeg9152.50 |
05-23-2019, 09:42 AM | #387 | |
Rep 4,819
05-23-2019, 09:44 AM | #388 |
Rep 12,722
did you watch the whole vid? looks incredibly easy like you can turn it on/off/run it at will. you can even setup different cycle calendars for different times of the year, like a summer/winter schedule.
RickFLM410954.50 |
05-23-2019, 10:04 AM | #389 | |
Rep 308
RickFLM410954.50 |
05-23-2019, 11:22 AM | #390 |
"Salud"
13776
Rep 4,663
Drives: F01 & F15 / Mineral White
05-23-2019, 11:23 AM | #391 |
"Salud"
13776
Rep 4,663
05-23-2019, 03:00 PM | #392 |
Rep 14,522
those STRIPES tho! CarbonX is making my grass grow ridiculously fast. it's only been 2 days since my last cut
05-23-2019, 06:53 PM | #393 |
Monkey Marshall
623
Rep 218
05-23-2019, 09:33 PM | #395 |
Rep 12,722
Avocados getting bigger!
bosstones1154.00 nyalpine907423.50 |
05-23-2019, 09:35 PM | #396 | |
Rep 1,543
Yeah, GCI carries Carbon-X but he's been out for a while as well. Oh well. I just mowed a little lower in the backyard (2.5") since I'll drop some top soil, seed, and throw down a starter fert and won't be able to mow for a bit. Was thinking of putting down RGS as well prior to the seeds and fert. I cut the front to 3" and will put down RGS tomorrow. If the Hyr-Brix comes in, I'll put that down. Otherwise, I might just try that GreenYard stuff as a final (well...only) pre-summer feed.
- Jeff
bosstones' flickr |
