      10-03-2013, 04:28 PM   #1
alfredoporro
Drives: 2011 BMW X5 xDrive35i Titan Si
I just bought a 3.64 differential! what else to replace while installing it?
Hello!
I just bought a 3.64 differential with 22k and it will be arriving next Wednesday !
I know I will need the differential fluid and the draining/filling plugs for it. is there anything else I need?
I'm very excited about it
      10-03-2013, 04:40 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Interested, because I'm about to install my 3.64 too.
      10-08-2013, 12:30 PM   #3
pokeybritches
2006 BMW Z4M  [8.50]
:crickets:
Hopefully I'll be installing it this week.
      10-08-2013, 01:03 PM   #4
beta
Drives: 2006 M Roadster
I know it's not the M diff, but you may need similar parts? (crush sleeve, etc.) Check out the 3.91 thread, then maybe do some realoem see if you can find if any of the parts are shared, or what the equivalent would be.
Not a lot of help, but maybe it will get you in the right direction.
      10-08-2013, 01:22 PM   #5
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
The minimum is replace output shaft seal. I had a diff swap before because shop did not replace new seal. Diff started leaking and I have to pay for labor to redo it. Not very happy with the shop.
