      10-08-2013, 09:49 AM   #1
noogi
noogi's Avatar
Drives: 07 z4 m roadster stock
z4m differential drain plug size
need to change the diff fluid..; to remove the drain plug, is it hex socket size 14mm?:
      10-08-2013, 09:59 AM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10847
Drives: Z4 3.0i ESS TS2+
I think it is yes.
Hex key 14mm that is.
(a 6pt socket is also sometimes called a hex socket but that won't fit obviously)
      10-08-2013, 10:53 AM   #3
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Yes. 14mm hex bit socket. I suggest you get new plugs. They are suppose to be one time use.
      10-08-2013, 11:56 AM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
get this set. Makes your life easier
http://www.ebay.com/itm/EZ-Red-6pc-M...209303&vxp=mtr
The Raspinator
      10-09-2013, 12:47 PM   #5
noogi
noogi's Avatar
thanks for all the responds; appreciate it;
      10-11-2013, 11:56 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Wow. Thanks!
That's the handiest set of widgets I've seen in a while.
Order placed. About 5 bucks cheaper off Amazon.
      10-12-2013, 09:48 PM   #7
SCHMOUPE
SCHMOUPE's Avatar
Originally Posted by StickMon View Post
Wow. Thanks!
The Raspinator
