      01-16-2012, 05:28 PM   #1
-c-
-c-'s Avatar
Drives: bmw
standard primuium sterio upgrade to dsp navi retrofit help.
Hello guys need to ask for your help on this one!
ok here it goes! my Z4 has the standard premium sterio setup and i need to retrofit the nav system that i have and i have the sterio from Chris fine's car.
his is the DSP nave system.
so im trying to convert the wireing harnes from his car to my car. since the harness is different between the two amps wireing wise i just just need to know which wires to swap from my old harness to the new one.
i took out the old wires that were cut from his old harness before really diving in and that was a mistake.
here are the pictures between the two harnesses and just need to know if anybody knows what i can do to easily swap the wires so the new amp will work with the system.
thanks guys!
again this is converting the standard premium sterio to the DSP nav system.
here is a pic of the two amps,
here is the part numbers,
here is a shot of my standard premium sterio amp wire connect.
here is a shot of the DSP wire loom with the speaker wires removed and a few power lines.
as you can see the plugin looks identicle.
so what do you think guys! should i just unglug the wires from the one loom and plug them into the other?
      01-16-2012, 10:40 PM   #2
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Here are some pics of the connector to the DSP amp in my car... Sorry it was a bit dark in the garage..
