      04-20-2020, 04:31 PM   #1
wdb
dances with roads
wdb's Avatar
4722
Rogue Engineering X-Pipe
New price $1.86 Yes really. (Stupid pricing tool won't let me put in pennies so it says $2.)
I bought this used from a forum member. However I was unable to get an acceptable fitment with this piece and my Eisenmann Sport rear cans, so it is back up for sale.
I suspect it is an early unit, which from what I have read had some fitment issues. As the pictures show it has a piece added on one side. Based on my fitting experiences this was done to equalize the lengths, and to that end it worked very nicely. But I could not get the vertical alignment I wanted, and I lack the tools to manipulate the pipe to suit my needs.
The piece is in good shape overall as the pictures will show. The added-in piece might look rusty in the pictures but I'm pretty sure it's stainless like the rest of the unit, discolored from heat of welding. The welds keep the flange fitting on that side from moving downward but it will rotate. I had no problem getting bolts lined up.
Even at this price I'm willing to drive halfway to deliver, up to several hours. Maybe you can buy lunch. I will ship but it would be "drop it off at the shipping site and buyer pays for the entire cost" deal. Last time I checked that was $everal hundred$.
This is definitely your least expensive chance to own an RE X-pipe. If you have more tools than I do, or if you know a good exhaust shop, I'm confident you can make it work.
      04-20-2020, 08:23 PM   #2
maupineda
Drives: E86 Z4MC
Hi there!!
The vertical alignment of the mufflers is set by rotating the flanges. I had the exact same issue with the super sprint x-pipe I bought and I was about to give up completely and install the OE thinking the problem were the x-pipes. I just couldn’t believe I had bad luck with two different pipes. Believe me, that day I had the same issue with the SS I wanted to cry!
I am sure this was the issue I had and I did not need replacing anything. When I bought the car and had the Stromung mufflers they where spot on!!!
Pro-tip, if you set the flanges more or less horizontally the mufflers hang low. It helps to lightly tighten the flanges of the pipe and muffler and start spinning them around, you will see what position rises the mufflers as you spin them, then support the muffler and tight the flanges, it may be that you will need to tighten one side of the flange more than the other to achieve the perfect placement (side to side).
This was an $800 lesson I learned (the cost of the SS x-pipe)
AK72286.00
Vanne1620.50
      04-27-2020, 11:59 AM   #3
wdb
dances with roads
wdb's Avatar
4722
Originally Posted by maupineda View Post
Hi there!!
The vertical alignment of the mufflers is set by rotating the flanges. I had the exact same issue with the super sprint x-pipe I bought and I was about to give up completely and install the OE thinking the problem were the x-pipes. I just couldn稚 believe I had bad luck with two different pipes. Believe me, that day I had the same issue with the SS I wanted to cry!
This is the person I bought the X-pipe from. I can't say that I tried every combination of flange rotation when I was trying to align the mufflers, so this may be the issue.
      04-27-2020, 04:55 PM   #4
CJW2OO4
CJW2OO4's Avatar
Hi where are you located?
      04-28-2020, 05:44 AM   #5
wdb
dances with roads
wdb's Avatar
4722
Replied in PM. Thanks for the interest!
      05-03-2020, 12:30 PM   #6
wdb
dances with roads
wdb's Avatar
4722
I priced shipping to Canada for one interested party. It ain't pretty. I think someone in the Mid-Atlantic region or thereabouts is going to end up with this. Make me an offer.
      05-08-2020, 03:16 PM   #7
wdb
dances with roads
wdb's Avatar
4722
I am picking up an E350 longroof tomorrow. I'm sure it would love a road trip...
      06-24-2020, 01:40 PM   #8
wdb
dances with roads
wdb's Avatar
4722
Still available. Make an offer.
      11-15-2020, 08:36 PM   #9
wdb
dances with roads
wdb's Avatar
4722
B-b-b-b-b-bump
      11-15-2020, 10:31 PM   #10
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Have you seen this installation guide => https://www.zpost.com/forums/showthr...r+installation
You should give it another try as the RE X-pipe will bring those Eisenmann Sport to life!
      11-16-2020, 01:15 AM   #11
toorawshaw
Drives: Z4 e85
Where you located
VF Supercharged 03? E85 Z4
      11-16-2020, 10:37 AM   #12
wdb
dances with roads
wdb's Avatar
4722
Originally Posted by toorawshaw View Post
Where you located
East coast.
      11-16-2020, 10:21 PM   #13
RossBMWZseries
Where on the east coast?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      11-17-2020, 05:45 PM   #14
wdb
dances with roads
wdb's Avatar
4722
Eastern Pennsylvania. I am more than willing to do a bit of driving in order to ensure that it finds a new home. Texas may be a bit far though!
      11-21-2020, 11:07 AM   #15
RossBMWZseries
I知 currently in Brunswick Georgia though lol. So that extended add-on piece, is there any air leaks or issues with that section?
Not sure if I知 understanding correctly, but you had problems installing this X pipe in your car because you couldn稚 get your mufflers to line up properly on the rear bumper?
      11-21-2020, 11:42 AM   #16
wdb
dances with roads
wdb's Avatar
4722
I’m currently in Brunswick Georgia though lol. So that extended add-on piece, is there any air leaks or issues with that section?
Not sure if I’m understanding correctly, but you had problems installing this X pipe in your car because you couldn’t get your mufflers to line up properly on the rear bumper?
Georgia is a bit better. It was an alignment problem, not a leak problem. I could not get the mufflers and the x-pipe to cooperate on being in the places I wanted them to be.
      11-21-2020, 07:20 PM   #17
RossBMWZseries
I see. I知 interested but I知 afraid I値l have the same issues as you.
      06-02-2021, 08:24 PM   #18
wdb
dances with roads
wdb's Avatar
4722
New price. $1. It must have fit someone’s car else it would not look so well used.
      06-03-2021, 06:46 AM   #19
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
how far are you from Cleveland?
Powered by
      06-03-2021, 06:54 AM   #20
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
PM sent.
Revolution of our Times
I will return to the track, one day.
      06-22-2021, 04:56 PM   #21
E86Z4MC
Drives: Z4M Coupe
Is this still available for pickup? Driving through Pennsylvania tomorrow and again on Sat/Sunday for possible pickup.
      07-11-2021, 03:21 PM   #22
wdb
dances with roads
wdb's Avatar
4722
Given the recent upswing in prices I decided to drive a harder bargain. It finally went to its new home yesterday, and I got $3.86 for it! Thanks for meeting me e36taylor and thanks for the ice cream.
