      01-17-2019, 11:20 AM   #155
njburns
Drives: Z4 E85 2.5i
Thanks for the advice :-)
      09-11-2019, 10:55 AM   #156
raptor_demon
raptor_demon's Avatar
Drives: 2006 z4 3.0i sport pkg
2006 BMW Z4  [2.75]
Originally Posted by raptor_demon View Post
well after 5 years and 2 children later, im finally going to do this mod. any chance we could get the photos updated?
thanks
Raptor
Well turns out i was wrong, i didn't do this back in 2017, i did however finish this upgrade on Monday!
so i have the 3 stage manifold installed, but i have not flashed the ecu.
i was looking in the INPA software and under the VIMDISA menu i was able to test the disa valves. what is interesting is when driving the valves are actuating, and i can feel the power increase in the 5k rpm range. is this normal for a stock 3.0i without the ECU flash?
      09-11-2019, 09:51 PM   #157
Mantraxalos
Drives: 2006 325i Manual
2004 330CI  [0.00]
2005 330I ZHP  [0.00]
2006 330I  [0.00]
2007 Z4 3.0  [0.00]
2006 325I  [0.00]
RSA delete failed on me
RSA delete failed on me, now my car just cranks. I have the bimmergeeks cable with latency set to 1 on COM 1 and the latest version of their standard tools. My laptop has Windows 10 on it.
I have an 07 3.0 and was tempted by the bimmerlabs batch file. I also posted at e90post as there are many there with so much experience in flashing. If anyone can help I'd be very grateful. Thank you.
This is the error that I received.
https://1drv.ms/u/s!AnlavCs9oGBdlM1dzxn-lYudrwEfhQ
      10-24-2019, 08:16 PM   #158
rjahl
rjahl's Avatar
616
Drives: Z4 35is
2012 Z4 35is  [0.00]
Being a month old, I'm hopeful you resolved this.
I can assure you the Bimmerlabs files for the 3.0 work.
      12-29-2019, 01:02 AM   #159
Mantraxalos
2004 330CI  [0.00]
2006 330I  [0.00]
2007 Z4 3.0  [0.00]
2006 325I  [0.00]
I never did resolve it. After about a month without the Z4, I attempted to flash the old 3.0 file back on and it worked without issues. I'll try again in the spring for the SI power.
      01-01-2020, 06:13 PM   #160
Terraphantm
Drives: E46 M3 Coupe
The bimmerlabs files should work. If one prefers, I can also supply a program variant that ignores the hours counter on the DME and allows the powerclass to be changed - that would allow you to flash an unmodified 3.0si tune.
      01-14-2020, 11:04 AM   #161
dano328xi
Drives: 328xi '07 -- 650i x drive '12
I used Bimmerlabs to flash to the stage 3. One of my disa valves broke so I'm going back to stock. I already put the old manifold on. What files do I use to flash back to original? Also, Bimmerlabs website is down. thanks
      01-14-2020, 07:59 PM   #162
Terraphantm
Just do an "upgrade" with WinKFP, that should flash it back to the latest version of a stock tune
      01-15-2020, 07:20 PM   #163
rjahl
rjahl's Avatar
616
Drives: Z4 35is
2012 Z4 35is  [0.00]
Bimmerlabs was down for a short period. Hassmachine has it up and running again.
