05-26-2021, 08:57 AM | #1 |
Rep 20
Wanted Z4MC Suspension
Hi everyone,
I'm on the lookout for an OEM complete suspension for a Z4M Coupe. It's got to be complete, with top mounts etc. because I've purchased a B12 kit which is just the bare shocks and springs. Located in UK but if anyone is willing to post I'm open to that too. Thanks! |
06-22-2021, 12:17 PM | #9 |
Rep 410
I do, but with 50k on mine, I don't feel right about selling it to you. Add international shipping, you're better off buying new struts (and the other components are cheap). I bought everything to pair with my b12 kit as well. Here's the parts list:
FRONT: No. Description Qty Part Number 1 Guide support 2 31308040203 3 Articulated disk 2 31332282679 5 Upper spring pocket w/axial cage bearing 2 31331090612 6 Support 2 31332283038 7 Spring pad upper 2 31331091233 9 Additional shock absorber, front 2 31307836823 11 Spring pad lower 2 31331096664 I DIDN'T NEED: 2 Self-locking collar nut 6 31316769731 4 Self-locking hex nut 2 31106779396 8 Front coil spring 2 31307838835 10 Rubber boot 2 31331093344 REAR: No. Description Qty Part Number 3 Protection tube 2 33521136283 4 Auxiliary shock absorber, rear 2 33507838832 5 Plate 2 33526762325 9 Plate 2 33526788999 11 Spring pad lower 2 33531094518 13 Spring pad 2 33531136385 I DIDN'T NEED: 1 Shock absorber, rear 2 33507838645 -- Self-locking hex nut 2 33526773882 -- Hex bolt 2 7119900402 2 Hex bolt 2 7119900402 8 Self-locking collar nut 4 7119905374 10 Self-locking hex nut 2 33526773882 12 Barrel spring rear 2 33507836827 6 Guide support 2 33526779670 7 Washer-gasket 2 33526772864 I opted for Rogue Engineering Rear Shock Mounts, so if you are not going that route, you may need a few components for the rear that I did not. If you really want my used parts, let me know what exactly you want, and I'll sell them to you for dirt cheap, but again, with international shipping, I doubt it'll make sense vs. buying new from one of the typical players. |
