      03-29-2019, 07:16 AM   #1
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Dynamic Brake Control (DBC)
Hope someone on here has some experience with coding out the DBC in our cars.
http://www.bmw.com.kh/asia/en/insigh...e_control.html
Always found our cars require an extra light touch on the brakes in a track environment.
Recently, read about this feature and believe it may be the root of it.
Hoping someone has done it and can feedback any observed changes.
Thanks!
      03-29-2019, 08:51 AM   #2
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
A few people on Z4-Forum have done exactly that.
https://z4-forum.com/forum/viewtopic.php?f=9&t=103844
      04-02-2019, 05:18 AM   #3
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
You can also over come this by being gentle with the trottle. Buy I agree, coding it out is the way to go.
      04-02-2019, 08:48 AM   #4
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
What are the symptoms of this DBC interference?
I can't say that I've noticed anything amiss with my brakes on track.
      04-02-2019, 10:43 AM   #5
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Does DBC always remain on? Even when all traction control is turned off?!
      04-02-2019, 01:00 PM   #6
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Basically the brakes are inconsistent in their sensitivity. If you come off the throttle hard and go right on the brakes, the DBC system builds pressure so you get maximum (feels like it) braking with less pedal travel, thinking you're in an emergency situation.
That's why what Vanne suggested should work. If you are gentler off the throttle it likely won't activate DBC.
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      04-02-2019, 03:48 PM   #7
Michael9218
595
I wonder if my custom tune has this turned off. I definitely abruptly go from WOT to hard brakes and haven't noticed anything inconsistent.
      04-02-2019, 06:51 PM   #8
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
In certain situations, it feels like the braking system is over boosted with minimal peddle movement to reach maximum brake and very little modulation.
Hoping to find someone locally to code this out.
      04-29-2019, 07:24 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
I get this a lot during "normal" street driving.
Never learned to properly heel-toe, so I go from brake to stab the gas to brake very quickly on downshifts.
When I get back on the brake 50% of the time I get "hyper-brakes".
      04-30-2019, 01:04 PM   #10
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Same here - I specifically went back an analyzed my data overlaid on my videos and cannot see any signs of this at the track. I do however prime my brakes with my left foot when entering hard braking zones so perhaps that helps... or maybe the previous owner removed it.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      05-26-2020, 08:09 AM   #11
enzoaus
Drives: BMW Z4m
DBC is only active when DSC is enabled ...
greetz from Europe
      05-26-2020, 08:37 AM   #12
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
greetz from Europe
Are you sure? i was under the impression its always active? i dont track with traction (DSC) on, yet mine def pre-pressurizes the brakes when i am rough with the gas (a lot of the time lol)
Powered by
kaybat125.50
      05-26-2020, 08:45 AM   #13
enzoaus
Drives: BMW Z4m
this was the Info of the BMW Engineer who "coded out" the function in my DSC unit ... So I am not able to check it any more ... I dont feel any differences wiht my brakes (135i Calliper front, Endless ME22) on track (DSC off)...
      05-27-2020, 03:21 AM   #14
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
if its only on with traction on, why would anyone bother to delete it?
Ill check my logs on the next run, however, as ill probably be deleting the brake booster, it will be of no consequence.
hmm.. nope DBC is always on regardless of DSC, the other one is connected to SBC, CBC, that gets turned off with disabling DSC (with the button),
DBC is a complete seperate system.
its ON even when DSC is off. (unless you've, or your tuner codes it off)
I think your confusing CBC with DBC mate
Powered by
      05-27-2020, 08:21 AM   #15
enzoaus
Drives: BMW Z4m
I have to admit I'm wrong and you're right, I confuse CBC with DBC ...
I am very sorry ...
      05-27-2020, 11:16 AM   #16
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
No worries bud, no apologies required, I stuff shit up all the time.
Hows about a nice intro and pics of your car in the general/introductions part of the forum. Welcome aboard.
