06-26-2018, 03:29 PM | #1585 |
Rep 202
That's the OEM box.
2006 Z4 ///M, Interlagos Blue/Beige
06-26-2018, 11:53 PM | #1586 |
636
Rep 3,124
Replaced my Headlight Armor.
Holy Mother of Pearl, what a faff !!! It does protect the headlights from Sun damage, but the overlays get damaged at about the same rate. Having done the 3M restoration kit, and now replacing the Headlight Armor, I would only recommend Headlight Armor if you're worried about rocks breaking the headlight. Takes about 1/2 hour per side to do the restoration, and about 2 hours per side to get the Headlight Armor glue off.
06-27-2018, 10:56 AM | #1587 | |
Rep 2,867
06-27-2018, 12:23 PM | #1588 | |
dances with roads
4732
Rep 4,096
kaybat125.50 |
06-27-2018, 12:36 PM | #1589 |
Rep 202
Yes, I think anything longer than 1/2" will be too long.
06-27-2018, 12:49 PM | #1590 | |
Rep 528
Drives: E86 Z4MC; E92 M3
Before installing I had lined the inside of the boxes with felt (standard stuff from an arts and crafts store) and the finished result was one I was quite proud of. Helped to reduce/eliminate any of the plastic-y sound when you put something inside that rolls or slides around.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
06-27-2018, 06:05 PM | #1591 | |
636
Rep 3,124
Scrubbed the glue off with WD40 and a shop rag.
06-27-2018, 07:23 PM | #1592 | |
Rep 42
06-28-2018, 12:03 AM | #1593 |
Rep 202
Make sure to also order the mounting bracket, as it is not included with the first aid box. The bracket costs more than the box.
06-28-2018, 12:27 PM | #1594 | |
Rep 55
06-28-2018, 06:39 PM | #1595 |
Rep 1,689
Wasn't going to get anything else for the Z after the A/C repair.
But then this showed up in my email yesterday, so at least I waited until today to get it... |
06-30-2018, 01:10 AM | #1597 | |
Rep 202
06-30-2018, 01:27 AM | #1598 |
Rep 202
Another bit of storage to be gained is to replace the useless SOS buttons with an oddments tray. It can fit a pair of sunglasses, some coins or maybe a cell phone (unless you got a pretty large phone).
See http://www.zpost.com/forums/showthread.php?t=1196385. However, don't pry the SOS buttons out from the front like shown there, do it from the back, as it is much easier. Also, do not disconnect the buttons, as it will throw a code in GM. The buttons can be popped out from the enclosure. Then just stuff it down the hole.
wdb4732.00 |
06-30-2018, 09:10 AM | #1600 |
dances with roads
4732
Rep 4,096
No pics but I bought all new lights for the front end of the M Coupe. I installed them yesterday.
I only pre-purchased the xenon bulbs/igniters, figuring that I could pop out the marker/signal bulbs and run down to the local auto parts house to get replacements once I had them in hand. Nope! BMW uses a rather unique halogen bulb, Philips 12356. I finally found them at the third place, a NAPA store, thanks to the first NAPA store cluing me in on where to go. Thanks NAPA! The job wasn't hard but that was only because I had researched the procedure in advance. Thanks Pelican Parts! Their information made the job MUCH simpler. The only really tricky bit was getting the xenon igniter power connector secured. It's loose until the igniter is rotated into its final resting place. Take your time and be sure about it. https://www.pelicanparts.com/techart...eplacement.htm Moral: buy front marker/signal bulbs online, you might not find them locally! |
06-30-2018, 12:51 PM | #1601 | |
Rep 820
Drives: 2007 Z4MR silver grey
06-30-2018, 01:11 PM | #1602 |
Rep 202
Were they using a scanner that reads BMW specific codes? I got a code (I forget exactly which one) then reconnected the buttons, cleared the code and it did not come back. Anyways, it is better to err on the safe side and keep the buttons connected. They tuck out of the way in the hole, so no harm no foul.
07-02-2018, 07:19 PM | #1603 |
Rep 12,565
Couldn’t let The HACK be the only one to pair their Z4 with a torque monster so picked this up over the weekend
The i3 will replace my E90 commuter car |
86Zed932.00 |
07-03-2018, 10:07 AM | #1604 | |
Rep 779
Where did you get this from.. i need a set too
-Roranji
07-03-2018, 10:23 AM | #1605 | |
Rep 202
You need part#'s 52107045018 and 52107044958 Then find some 1/4" x 1/2" self tapping sheet metal screws locally. I found ones at Ace Hardware.
07-03-2018, 10:34 AM | #1606 |
Rep 355
i had no codes whatsoever when i took mine out.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
antennahead72.50 |
