08-01-2018, 06:08 AM | #67 | |
Rep 485
Part of me wants it, the other part of me likes the skill of shifting an H pattern. |
08-01-2018, 06:14 AM | #68 | |
Rep 485
I did have a tie rod heim joint develop play after only 5 track days. Could have been a fluke. SLR was quick to send a replacement. I went ahead and bought higher quality Aurora heim joints at my expense. I also had some of the hardware loosen. So check it frequently. I ended up double nutting everything and used marker paint. Everything seems to be staying tight now. |
09-15-2018, 12:03 AM | #69 | |
Rep 701
Just a quick lift of the throttle to unload the dogs then slam her into the next gear, only takes a fraction of the time it does in a sqncro H pattern box especially the dreaded 1-2 shift at 6k+ rpm. The syncro's just plain cannot keep up. I am entertaining the idea of dropping in a T56 magnum because you can easily get gearsets for them and PPG makes a helical gear option so street driving would be more pleasant.
10-09-2018, 11:34 AM | #71 |
Rep 485
10-09-2018, 06:39 PM | #72 | |
Rep 3
You can get my totally useful but self-leveling totally seized unit, plus some cash! Let me know if that's appealin'... |
11-20-2018, 07:10 PM | #73 |
Rep 485
Track pics
Ran the car at Barber Motorsports Park the other weekend. Photographer got some awesome shots. Barber is a beautiful track!
Car ran great. Turned a 1:39. Unfortunately, the driveshaft center bearing carrier let go ending my weekend early afternoon on Sunday. |
11-20-2018, 07:23 PM | #74 |
Rep 3,004
Michael9218
SO great to see the pics, and to know all the time, energy, emotion and money has been fulfilled. Barber appears to be a very awesome track, with elevation change, sweepers, off-camber, etc. Your car looks simply incredible.
Racerbruce
11-20-2018, 11:10 PM | #75 |
Rep 1,923
Great shots!!!
11-21-2018, 04:26 AM | #76 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
I have to get back over there in the Spring. The car is looking good!
11-21-2018, 09:05 AM | #77 |
Rep 485
Driveshaft
Pic of the failed driveshaft center bearing carrier. The driveshaft was a tad too long when I got it back from the driveshaft shop. Lesson learned. I gave them an amount to take off, but didn't take a final measurement. It fit, but was tight. This apparently put too much stress on the rubber webbing that floats the driveshaft. 2,000 track miles and it let go. I guess I need to get it resized. If I'm going to do that, I might as well take off more...
Vanne1623.50 |
11-21-2018, 09:16 AM | #78 |
Rep 485
Oil cooler
Decided to do a little more to the car over the winter.
First up is relocating the oil cooler. Stacking it in front of the radiator worked ok, but while oil temps were very good all summer at around 250, water was higher than I liked at 200-205. The oil cooler was blocking 22% of the radiator surface area. Essentially blowing hot air into the radiator behind. So I moved it to the side so it will get dedicated airflow on the passenger side behind the stock brake duct hole. This should greatly improve water temps and also make it easier to tape over the oil inlet when it's cold. |
11-22-2018, 10:55 AM | #81 |
Rep 3,004
Yeah, what he said....
Isn't the S54 OEM a "semi-dry sump" system?
Are you converting to a full blown dry-sump?
Racerbruce
11-23-2018, 04:37 PM | #82 | |
Rep 506
11-23-2018, 04:59 PM | #83 | |
#buildnotbought
11053
Rep 4,923
Normally the drive shaft is 2 piece with a splined section that can vary the lengt a bit. Was the splined section completely retracted (pushed in) when you fit it to the car? And did you notice vibrations while driving?
11-23-2018, 05:25 PM | #84 | |
Rep 485
When it finally went the vibration was very violent accompanied by banging at certain speeds. I thought I had a rear tire separate. That's what it felt like. Until then, no sign of issue. |
11-23-2018, 05:31 PM | #85 |
#buildnotbought
11053
Rep 4,923
I think that if its still a snug fit with everything retracted, the propshaft is forced to sit in an angle. And when rotating, that gives a lot of movement & stress on the thin rubber membrane surrounding the centerbearing.
11-25-2018, 01:53 PM | #86 | ||
Rep 1,923
Also. The slr front control arms. Don't they give more steering angle? Isn't it meant for drift cars? Also share your thoughts on the lexan.
11-26-2018, 06:10 AM | #87 |
Rep 485
11-26-2018, 06:21 AM | #88 | |
Rep 485
P4P rear window is good. Excellent fit. I secured it with Tinnerman washers and RTV sealant. At speed you do see a little wobble in your rearview mirror. So far it hasn't blown out. Saves something like 11 pounds. It will scratch easily, so you need to take care with it. I wouldn't recommend it for a car that sees street use. I plan to replace the quarter windows with CF blanks when I install my GSR roof this winter. |
AriuSen776.50 |
