      11-30-2021, 08:40 AM   #1
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
BMW "Lifetime" coolant...
I must have one of the lowest mileage Z4M coupes on the forum. Currently at 31000kms(19220mi). I use her as a weekend toy in cottage country. The coolant is still dark blue and has no particles floating in it. The prestone tester says its good to -40c. Do I need to worry about changing it out due to this car being 14 years old?
      11-30-2021, 10:06 AM   #2
Squidd99
Squidd99's Avatar
Drives: 2008 Z4 3.0 Csi
I'd weigh keeping an old solution that's been circulating in that radiator for 14 years against the cost of some new coolant.
SD ///M42992.00
      11-30-2021, 01:01 PM   #3
Clearancediver
Drives: 2004 Z4
Definitely needs to be flushed….
Sent from my smart phone...
      11-30-2021, 03:25 PM   #4
grannyknot
grannyknot's Avatar
951
Drives: 2008 Z4M coupe
BMW's blue coolant is pretty good stuff but 14 yrs of heat cycles has almost certainly worn out some of the additives, probably time to flush.
2008 E86 M coupe
      12-03-2021, 01:39 PM   #5
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Even if you are changing it now, I fear some corrosion may have already started. It's not like aging fine wine here.
The Prestone bulb tester only confirms freeze/boil points. The invisible killer is the coolant acidity and resulting corrosiveness. You can use pH strip to test it. Or another way is by using a multimeter for conductivity. There is a tolerable range that you can reference.
      12-03-2021, 08:20 PM   #6
Squidd99
Squidd99's Avatar
ALSO, don't be fooled by names and labels: my guess is that "lifetime coolant" only means it's good for the life of the coolant (which surely died years ago).
This free tip comes with a double-your-money-back guarantee.
      12-09-2021, 08:59 AM   #7
Sergio19
Drives: Z4MR
S54 is a mixed metal engine (alum head, iron block) so corrosion is a big concern. Change every 5 years or less.
      12-09-2021, 02:09 PM   #8
rsutoratosu
Drives: Z4 3.0i
Thats what I figured also, I remember they turning acidic..
-Roranji
