10-13-2011, 10:47 AM | #23 | |
Rep 4,726
Un balanced brakes will activate the ABS very early as you lock the rears up before the fronts are even near the threshold or vise versa.
10-13-2011, 11:11 AM | #25 | |
Rep 170
on later M3 uses the Teves MK60, then there is the CSL and Competion package version which has a higher threshold of activation and lastly the Race version which has user adjustable settings. All of these units use the same basic hardware the only difference is the SW. If the ABS threshold was based strickly on wheel speed all units would activate at the same time under the same conditions. However there is a noticeable difference with all three, especially under bumpy conditions. BTW - I was referencing the G-Sensor since this was the easiest way to show when BMW changed there ABS systems to reference more than just wheel speed. They reference Brake line pressure, G and yaw as well as WS. |
10-13-2011, 11:35 AM | #26 | |
Rep 170
When I was saying innitial bite I was refering how the brakes react with the same amount of pedal pressure upon brake application. One set up may a very high initial level of friction while another initial frition may be lower and builds. |
10-13-2011, 12:14 PM | #27 | |
1821
Rep 5,337
But the entire point about upgrading to bigger brakes offering immediate improvement on stopping distance? Pure bull. Even Zeckhausen will tell you otherwise: http://www.zeckhausen.com/Testing_Brakes.htm#Summary Between the stock 350Z track brakes and the StopTECH big brake kit, the stopping distance for 100-0 actually increased slightly on the same RE040 tires with StopTECH's kit. And notice the BEST stopping distances are all within a statistical anomaly of each other. Where you WILL see improvement on a big brake kit is if the test is repeated time and time again, the fade resistance part of a larger heat sink is going to dramatically impact the result (see how the "average" distance improves with big brake kits). And as far as calling each other names...I think the public will likely know who's blowing smoke and who actually knows what they're talking about here, O-Cha. At least *I* don't have an ulterior motive here (I no longer have any associations with RacingBrake, nor any brake vendor/manufacturer).
10-13-2011, 01:25 PM | #28 | |
Rep 170
and ABS control is incorporate into the same units. Straight line braking is affected by the this system the greatest difference is felt under bumpy conditions the ABS kicks in later with ZCP unit. Without arguing further if you research the topic a good driver without ABS can outperform a street based system (on good rubber / in the dry). The Teves and Bosch M4 sytems are another story. Outside of the ABS debate, I agree that much of the hipe over big brakes is not founded or realistic and mainly cosmetic. However there isn't a black of white answer to whether all Big brakes increase or decrease / stopping distances. The only way to prove right or wrong is to do back to back tests with both factory and aftermarket brake using the same pad compounds and temps. Brake pads play a major roll in the outcome. In the end the only reason I commented was your harsh statement... |
10-13-2011, 01:32 PM | #29 |
Rep 5,329
i cant lie when i did my AP BBK i definatly noticed shorter stopping distances, i also noticed the with rear 4 pots the car doesnt stand on its nose like i used to, the rears a definatly taking up more of the braking........ i think the OP is pretty much bang on with what he's experiencing...
Ochas is correct, you really can leave mad tyre marks under really heavy braking..... infact it feels like something is going to break!! lol OP can you post some "bedded in" pics, i love to see a burnished Rotor!!
10-13-2011, 02:12 PM | #30 |
Rep 12,565
Agreed but I would say initial bite is a function of the pad, not the big brake kit.
10-13-2011, 02:27 PM | #31 | |
Rep 4,726
Additionally, ABS activating or not under bumpy conditions is going to have a lot more to do with suspension tuning anyways. Tires losing contact with the surface will IMMEDIATELY activate abs, anyone who has races on a track with rough spots and ABS will tell you this, turn 16 at Sebring has a rough patch right in the racing line notorious for activating abs. The reason a good driver can "outperform" abs is because ABS is not, and was never intended, to allow a driver to stop faster, in fact activating abs makes your stopping distance LONGER. ABS is there for one reason, to allow panicked drivers who would otherwise lock up their wheels to be able to steer around an obstacle instead of careening straight into it because they locked the front wheels and can no longer steer. It does this by pulsing off the applied brake pressure. A really fun test you can do is put some tires on your car that are grossly mismatched in diameter, then speed to 100mph and try to stop, you will scare yourself as ABS activates without hardly any wheel slip and your brake distance is extended 100s of feet. Knowing this about ABS alone should tip you off as to why it is more then possible that a brake upgrade that changes the balance can effect a decreased stopping distance. Pretty much any test you do is going to be completely inconclusive, you aren't controlling the variables at all by just doing a back to back comparison, by design they are going to require different testing conditions to provide optimal performance to begin with.
10-13-2011, 02:28 PM | #32 |
Rep 4,726
And Hack, I told you I agree with your basic premise but the things I presented are facts, that you refuse to admit you overstepped by making a sweeping generalization (that is wrong) while berating a user, thereby making an ass of yourself, is not my problem.
You cannot submit any rebuttal to my stated fact that the stoptechs provided better balance on MY setup specifically because you don't have them, you don't know my setup. You also cannot submit a rebuttal to the fact that I stated it's quite possible the brakes made it EASIER for him to threshold brake much better, because you stated this yourself. If I add a proportioning valve to a brake setup, it sure as shit is going to make me stop faster (assuming rears are over-sized). It has nothing to do with the size of the brakes or the calipers, but them matching the car better. You cannot disagree with this, and yet this is essentially the statement I have made, that it is possible for the change in brakes to be more then just a difference in size and type. Therefor your sweeping generalization is proved wrong, have a nice day.
10-13-2011, 03:34 PM | #34 |
instagram 997turbotom
279
Rep 7,377
All I know is when slowing down at close to the thresh-hold from 125mph, I'd much rather have bigger and better proportioned brakes than on my stock brakes
10-13-2011, 04:16 PM | #37 |
Rep 12,565
Way too much arguing here. I think we can all agree a big brake kit is most beneficial in addressing fade issues which would only result on the track. Any improvements seen/felt on the street by OP are real but presumably could've been achieved with ss lines and better pads. Hack, O-cha are both right...
10-13-2011, 04:55 PM | #39 | |
Rep 4,726
I don't feel like uploading the actual technical literature, so here's the first hit for "BMW ABS" I can assure you the technical literature also states it's based on wheel speed. http://www.bmw.com/com/en/insights/t...ke_system.html Again you are correct that brake line pressure, G and yaw sensors are fed through the DSC module, but I assure you these are for DSC.
10-13-2011, 08:51 PM | #40 | ||
Rep 170
willing to put in the effort to agrue futher. I am not saying that the ABS system does not look at WS. What I am saying is that in modern systems G sensors/yaws sensor/line pressure,... are factored into the operation of the ABS. Based on what information are you assuring me that I am wrong? Are you sure other data is only used for DSC? See attached info on the Bosch M4 System it touchs on the inputs and the design parameters of street / race systems. http://www.bosch-motorsport.de/conte...rochure_en.pdf Quote:
wheels = no ABS, however other sensor inputs affect how and when the ABS will react. 2 - If you remove suspension settings from the equation, more preformance oriented ABS Systems will not lock up as easily as a street based units. Ask any of the top running Grand AM GS teams (almost all of them run either the Bosch MS / or Teves MS units)and they will confirm that not all ABS systems respond the same in bumpy conditions. 3- This is the point I initially raised. ABS is a limiting factor in min. stopping distances. 4- Changing brake balance can definetly affect brake performance both positive and negatively. Most street cars have too much front bias. 5- Agreed |
10-13-2011, 09:38 PM | #41 | ||
Rep 4,726
I don't see the point you were making with this statment then Quote:
10-14-2011, 04:03 PM | #42 |
Rep 1,739
Drives: 2008 Z4MC
*yawn*
I'm sure there's a happy medium somewhere for less than $8000++ Nice brakes either way, congrats OP |
10-15-2011, 02:59 AM | #43 |
Rep 606
Is it strange that the only thing I really envy about a BBK setup is the ease at which you can change brake pads?
10-15-2011, 07:22 AM | #44 | |
Rep 5,329
These type of BBK kits come into play really when you doing a decent amount of track days, but i have to admit, being able to swap the pads out in 8mins a side once the cars in the air is awesome..... i run pagid blues which are great at the track and seem good on the road at the cooler temps as well.......
