      07-15-2011, 04:31 PM   #1
tikamak
Lebanon
58
Need new Z4M Rotors, suggestions?
My front rotors have gone to brake rotor heaven so i need new rotors / pads. I've changed pads for now because i can't help myself, i need to take the car for a spin or i will die.
What i know so far from research is that the OEM rotors are a 2 piece floating rotors and rank pretty high in performance and what i basically need is just to get OEM rotors, some aftermarket pads e.g.: axxis ultimate (very low dust) and to upgrade the brake lines to stainless steel and do a fluid change with a bleed, that should make the OEM braking feel much more solid then it is.
Any suggestions based on experiences? i'd like to have some feedback.
      07-15-2011, 04:33 PM   #2
tikamak
Lebanon
58
If you'd like to suggest a better aftermarket alternative that will fit on stock calipers, please be my guest. be sure to state why you think so because it's important to me.
      07-15-2011, 04:46 PM   #3
sabbanick
Drives: 08 SBM M coupe
Depends how you use your car... For just spirited driving stock setup will be just fine.
One of the advantages of running a true two piece aftermarket rotor is that after the initial investment you just have to replace the outer ring...u reuse the hat thus saving some money.
      07-15-2011, 04:52 PM   #4
tikamak
Lebanon
58
Are you talking about the racingbrake rotors? if you are, I have come to realise that the rotor replacement cost as much as the OEM rotors so what's the point ? seems like i paid for an extra hat, that's it.
      07-19-2011, 10:15 AM   #5
tikamak
Lebanon
58
bumpers ... still need the help.
      07-19-2011, 02:41 PM   #6
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Racingbrake appears to be a better design, possibly longer lasting and/or lighter than the stock ones. Unfortunately, they don't stock our size any more, despite what it may say on the website. I tried ordering about 6 months ago. No go. They don't have our size "hats" any more.
      11-11-2011, 10:13 AM   #7
WarrenRB
Drives: m3
RB two piece rotor status just got updated.
http://www.zpost.com/forums/showpost...2&postcount=18
