10-09-2019, 03:03 PM | #1 |
Rep 431
FS/FT: 2006 Z4M Coupe Street/Track (66K Miles)
Up for sale is my tested and proven 2006 Z4M Coupe street/track car to help fund a race car for 2020. No expenses were spared and only the highest quality parts were used to ensure reliability. Also considering trades for IS/IP, HS/HP, GTS3 or SE46 race car. This Z4M is turn-key, ready to hit to the track and needs absolutely nothing. Professionally maintained and setup by Tyler Pappas from Tyspeed (Pikes Peak competitor & BMW CCA B-Mod 2018 Champion) and is fast. https://www.youtube.com/user/g35mr2/ - WGI: 2:07 - NJMP Lightning: 1:13 - NJMP Thunderbolt (No Chicane): 1:31 Silver Gray over Imola Red and Carbon leather. 66K miles, clean title and clean Carfax. VIN number and additional photos offered by request. Asking $35,000 Located in Freehold, NJ Clean NJ Title in Hand All items listed below have been performed within the past 8K miles / 2.5yrs with receipts unless otherwise noted: Current Weight: 3,140lbs w/o Driver & ¾ Tank of Fuel Engine: WPC Rod Bearings RKTune Tune (No CEL) CSF Aluminum Radiator CSF Oil Cooler (Custom AN SS Lines and Mounting Brackets) Valve Adjustment Valve Cover Gasket Rear Main Seal Coil Packs Spark Plugs Timing Chain Tensioner Rogue Vanos Line Various Other Seals/Gaskets Updated/Replaced Deleted EGR & AC Compressor/Condenser (OEM parts included) BW EGR Block-off Plate Exhaust: SuperSprint V1 Headers Rogue Engineering Exhaust (~30K miles) Rogue Engineering X-Pipe (~30K miles) OEM Secondary Higher Flow Cats still installed (no foul smell from exhaust) Drivetrain: Bimmerworld Solid Shifter New OEM Clutch Turner Solid Aluminum Motor & Trans Mounts Turner Solid Aluminum Rear Subframe Mounts Powerflex Black Poly Diff Bushings Suspension: JRZ RS2-NR (12 track days / <1K Street Miles) Ground Control 800/900 Springs Ground Control Race Camber Plates Ground Control Solid Rear Shock Mounts Ground Control Articulating Rear Spring Perches Turner Race Rear Camber Arms H&R Front Sway Bar Turner Adj End Links Powerflex Black Poly Bushings Reinforced Sway Bar Mounts Corner Balanced Track Alignment New OEM F/R Hubs New OEM Front Control Arms OEM M Front Strut Brace (rare) Brakes: Bimmerworld Brake Ducts Custom Brake Cooling NACA Ducts on Underbody Panel SS Lines Motul 660 Fluid Fresh OEM CSL Two-Piece Front Rotors (4 Track Days) New Master Cylinder Rebuilt Calipers (12 Track Days days / <1K Street Miles) New OEM Street Pads New Hawk DTC-70 Track Pads Safety/Interior: Wiechers Bolt-In 4-Point Roll Bar with X-Bar (All interior panels still fit without modifications) – 1 of 2 imported to the US from Germany Sparco EVOII Seats (expired) Sparco 6-point Belts (2022) VAC Hardware VAC Fire Extinguisher Mount w/ Extinguisher Rennline Pedals Jaffster Shift Knob Wired for AIM SOLO DL & Smarty Cam Braille #15 Battery (can swap with OEM if preferred) Macht Schnell Battery Mount ** Mint condition OEM Imola Red seats can be added for an additional cost ** Body: APR GTC-250 Wing APR Splitter Rolled Front Fenders Turner Tow Straps New OEM Windshield Cowl New Safelite Windshield Color matched front Reflectors Black Kidney Grilles (OEM Included) Wheels/Tires: Square 18X9 et30 Alzor Wheels --Apex ARC8 or D-Force w/ 275 Hoosiers can be added/replaced based on deal 275/35/18 BFGoodrich Rival Tires (200TW) (~12 Sessions) --265/35/18 Hankook Ventus V12 Street Tires can be swapped if desired BimmerWorld Race Studs (2 Track Days) Wheel Spacers (Front: 3mm / Rear: 10mm)
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo Last edited by Azeka1; 10-09-2019 at 04:10 PM.. |
10-09-2019, 03:27 PM | #3 |
Rep 431
Thank you and it really is difficult to let this go. The Z4M is truly an amazing car that is both exciting and rewarding. I am so glad that I had the opportunity to drive it at its limits. Definitely going to regret this...
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
10-10-2019, 11:34 AM | #4 |
Rep 9
Have seen this car multiple times in person and it is beautiful! Very well maintained by Tyspeed (i service my Z4M roadster there, fantastic shop!) and Afrim is a trustworthy guy. Buyer can purchase with confidence that they are getting a great car and deal here.
Sad to see her go |
Azeka1285.50 |
10-13-2019, 07:16 PM | #5 |
Rep 431
Sold - thank you for the interest!
10-27-2019, 10:05 AM | #6 |
Rep 12,565
Who’s the lucky buyer??
10-27-2019, 10:16 AM | #7 |
Rep 431
A couple very nice guys (brothers) from NYC picked it up within a day of posting it. They have a bunch of other cool track cars along with some classic M cars and track with HOD.
Hopefully we'll continue to see it being put to good use.
10-27-2019, 12:13 PM | #8 |
Rep 3,004
Congrats Azeka1!!!!
SO great that you created an incredible Z4MC.
Racerbruce
10-27-2019, 01:25 PM | #9 |
Rep 12,565
Congrats man, definitely one of the nicest built DD cars on the board. Excited to see what’s next for you. Let me know if you have any leftover parts you’re looking to unload cheap
10-28-2019, 11:43 AM | #10 | |
Rep 431
Only thing that I have left over is an OEM Z4M Front Swaybar with new OEM Endlinks.
