07-14-2019, 05:21 PM | #376 |
Rep 879
Know a guy on ig running 18x8 et 20 with 205/40 on BC's...would love to hear if you make it work, I'm about to redo my wheels / suspension but i can't figure out aggressive fitments lol
07-28-2019, 03:33 AM | #377 | |
Rep 40
Following up on my post 19x9 ET 32.. 235/35 19x10.5 ET 25 275/30/19 No fenders rolled. Before View post on imgur.com After View post on imgur.com The car.. View post on imgur.com Last edited by ZiMMie; 07-28-2019 at 04:05 AM.. |
3GFX722.50 |
09-09-2019, 09:46 AM | #379 |
Rep 422
Hey all, I've installed M3 CSL style wheel's on my '06 E85 3.0si w/86K miles and getting a little rubbing when I hit a dip in the road. Wheel size: F 19x8.5(35mm), R 19x9.5(40mm) with Michelin Pilot 4s 235/35 up front and 265/30 on the rears. Car has all stock suspension. Rear springs are not cracked but again, they're stock. I've looked at the tires and can't really see where it's rubbing on the rears. I'm getting some very slight rubbing on the outer corners of the front as well. Car was aligned with full negative camber. I've seen where folks have installed this size wheel/tire combo with no issues and have even lowered the car with still no issues. Could it be that the stock springs are just worn? That seems unlikely though.
2006 E85 Z4 3.0si
2015 F10 535i M Sport Sold 2011 E92 M3 Sold 2007 E90 335i Sold 2006 E90 330i Sold |
09-10-2019, 07:19 AM | #380 | |
Rep 912
Take off a wheel and look inside the fender. Could be suspension related, maybe a liner is drooping. Take a look, the wheel sizes look fine. |
09-15-2019, 04:28 PM | #382 | |
Rep 2,702
By my calcs you will be recessed from the fender lip approx 6mm in front and 16mm in back https://www.1010tires.com/Tools/Whee...et-Calculator# My Apex set of 8.5 et 35 fr and 9 et 30 is 6mm recessed in front and flush to fender lip out back
09-26-2019, 11:53 AM | #383 |
Rep 40
18x8 and 18x9 fitment question
Apologies if this has been asked and answered, I really did look (and do research various fitment guides) but I am getting lost in the numbers/concepts. Will the following fit a 2013 z4 35is without any need for changes to the stock set-up for the car?
Front 18x8 ET35 with 235/40 r18 tires Rear 18x9 ET35 with 265/35 r18 tires thanks! PS these are the specific wheels I am contemplating (the sight says they do not fit but I do'nt understand why...) https://www.ecstuning.com/b-alzor-pa...four/030-5kt2/ |
09-27-2019, 07:01 AM | #384 | |
Rep 912
09-27-2019, 11:51 AM | #386 |
Rep 1
09-29-2019, 08:51 AM | #387 |
Rep 1
Style 393 wheels fit???
looking to change the wife's sport package 18in wheels to 17in wheels for a more comfortable ride and found a set of style 393 wheels. Only difference I can find is the 393's came off of a 428i that uses an M14x1.25 lug bolt versus the E89's M12x1.5 lug bolts. Anyone know if the lug bolt size will affect the fit of the 393's? thanks
10-27-2019, 06:37 AM | #388 |
Rep 52
Once again I'm here to ask you gents.
CSL reps 235/35 8,5x19 ET 40 265/30 9,5x19 ET 45 Any rubbing on 3.0si without M suspension? I want to put B12 on this car, keeping that in mind, would you go fot it? I do not want any rubbing at all... Then again, these are standard tyre sizes to Aplina roadster S (ET 50 on front and rear) and M3 CSL, that is why I am curious. Should I switch to 225/35 on fronts? |
11-07-2019, 02:00 PM | #389 |
Rep 2
Hello,
I am went through this treat and I was not sure on the response for a specific wheel sizing. I have a 2004 E85 w/the sport package (stock) and wanted to put some 335i M wheels (style 193M) . They have all the same dimensions except for the ET/offset. Original car specs are: Front: 18x8 ET47 225/40 Rear: 18x8.5 ET50 255/35 Style 193 wheels are: Front: 18x8 ET34 225/40 Rear: 18x8.5 ET37 255/35 Does anyone have any experience with this set up or know if they have any rubber due or negative affects on the handling due to the -13 in offset? |
11-08-2019, 07:46 AM | #390 | |
Rep 912
The rims you mention are the exact same width and are really just gonna poke out 13mm more than the original car specs. Basically the width of an average thumb. It should hardly make any difference. It would be the equivalent of added a 13mm spacer which is fairly common to reduce the gap from fender to wheel. Everyone need to start using this: https://www.1010tires.com/Tools/Wheel-Offset-Calculator |
Mega4960.00 |
11-08-2019, 07:52 AM | #391 |
Rep 912
. . Quick google search of "Style 193 on Z4" yielded this. https://z4-forum.com/forum/viewtopic.php?t=24726 |
01-29-2020, 06:57 AM | #392 |
Rep 399
Having opportunity to get my hands on 359M style rims
Front Wheels: 9Jx19 ET31 235/35/19 Rear Wheels: 10Jx19 ET25 265/30/19 Need your opinion gents 3.0 SI with sport suspension Last edited by AK72; 02-04-2020 at 09:51 AM.. |
02-05-2020, 07:46 PM | #393 |
Rep 1
Okay. I read every post in this thread and I still have a question. I'm looking to pick up a set of these wheels
18x9.5 et35 (Square) 245/35/18 Car: e85 3.0 roadster. I did all the calculations showing how much more aggressive these will be compared to stock but the front seems a bit too aggressive. I plan on lowering with coilovers at some point. I can handle rubbing, I just dont want the car looking ridiculous with poke up front. My question is really about the front. Is that too aggressive? Need a fender roll? Dont buy? |
02-21-2020, 06:38 AM | #395 | |
Rep 382
I ran 513M on my non M Z4 and I'm currently running 260M on my Z4M. No spacers, no rubbing but the tire sizes had to be stepped down a size from what came with the wheels from the factory. |
AK72286.00 |
03-31-2020, 09:26 PM | #396 |
Rep 4
Good evening all.
I'm in the market for a set of staggered 18" Style 107's for the e85 Z4 http://www.bmwstylewheels.com/bmw/107 If anyone has a pair laying around lmk. Thank you. Last edited by krisfnbs; 04-01-2020 at 10:32 AM.. |
