      09-28-2010, 07:30 PM   #1
jumpthewire
jumpthewire's Avatar
Drives: 2007 silver/grey Z4 3.0si
DTC display
so i notice while driving around turns at moderate speeds the DTC displays briefly......
is that an indicator that the DTC is "working" or is this something i should be concerned about?
again, it only flashes briefly
      09-28-2010, 08:28 PM   #2
spurto
spurto's Avatar
Drives: 2006 Silver BMW Z4MR
2006 BMW Z4MR  [0.00]
thats normal during spirited driving it means it's working, you can press the DTC button and the car will let you have a little more fun and if you press and hold the button you can turn the system off completely and have a lot of fun
      09-28-2010, 08:30 PM   #3
jumpthewire
thanks! not sure if i'm ready for THAT much fun...yet
i also found this on another board....
"If the DSC kicks in for whatever reason (losing traction due to ice, gravel, hard driving), it'll flash a little light, looks like an ! inside a triangle inside a circle. Best i can describe it. Anyways, it's perfectly normal and just means you're driving her the way she's meant to be driven"
      09-29-2010, 12:09 AM   #4
johanness
Drives: 2008 Z4MC
I press the button and it light's up on the instrument cluster that it's been 'sorta' disabled. I press and hold it to TOTALLY disable it, but nothing happens. Is there supposed to be a chime or something?
      09-29-2010, 12:11 AM   #5
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
I was under the impression that the traction/stability control was either on or off in "M" cars, i dont think there is a sorta off
      09-29-2010, 12:13 AM   #6
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Samjam is right. On M-cars it's on or off... no middle ground. When the icon is displayed on the dash, it's off. On non-M-cars you do the quick press for the middle setting and press/hold for fully off.
      09-29-2010, 12:47 AM   #7
johanness
Drives: 2008 Z4MC
^^^ Thanks for the clarification. Got it. On/Off. Easy
      09-29-2010, 06:27 AM   #8
Huz-Z
Huz-Z's Avatar
That all sounds correct to me. I leace my DTC fully functional for day to day around town driving.
Too bad I can't program the car to say, when DTC is disabled: "Danger Danger, Will Robinson!!"
Cheers!!
Huz-Z
      09-29-2010, 08:27 AM   #9
jragan
Imola Lover
jragan's Avatar
Technically, it's not totally Off because ABS is still engaged (I believe the earlier generation ///M coupes you could turn the ABS off too...but I may be mistaken)
Hers: 997-1 C4S: Pics
      09-29-2010, 09:31 AM   #10
Hawkeye
Hawkeye's Avatar
No_Country
2070
I always turn mine completely off unless it has just started raining, is raining hard or the once or twice I have gotten caught in a freak snow.
      09-29-2010, 09:47 AM   #11
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
I don't mind that I can't turn ABS off. I think that technology has gotten so good that it's better than what I and most enthusiasts can do manually. Plus, there really isn't an argument for turning that off as there is for turning off skid control---it's not like locking up the wheels and having a longer braking distance is fun, whereas going sideways (intentionally) is very.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
