02-02-2020, 05:49 AM | #1 |
Rep 382
S54 Vanos Bullet Proofing
Vanos overhaul Completed yesterday. Everything was squeaky clean and tight with 63k on the motor. No loose cam bolts and no broken exhaust hub tabs. Only wear item was the chain tensioner and probably would have snapped in the next 20k miles. Vanos rattle is gone and car doesn't flatline between 7.5 and 8k anymore. If anyone local to the DMV area is looking for this service you must have DAFOE do it. Top notch guy and could probably do it with his eyes closed. This was the last preventative maintenance item on the list and now we wait for Turners new carbon air box, OEM catless headers and TTFS tune.
06-24-2020, 05:08 PM | #2 |
Rep 1,543
Is there a kit for the entire overhaul? Tabs, bolts, etc
parts cost & labor hours if you don't mind sharing? Thinking of doing this this summer...
FB Group-- > fb.com/groups/z4group Instagram --> @Skyermotorsport FB Page-- > fb.com/Skyermotorsport |
JimBob0047268.50 |
06-24-2020, 06:05 PM | #3 | |
Rep 382
Beisan Http://beisansystems.com/products.html S54 vanos oil pump disk S54 vanos seals repairs kit S54 vanos sealing plate repair kit S54 rebuilt vanos solenoid pack (optional) S54 exhaust upper chain guide Related Vanos Parts - ECS (12) updated cam bolts 07129905536 (1) Vanos gasket tel:11367831938 (2) Oil return washers tel:07119963129 (2) Vanos oil return washers tel:07119963072 (1) Crankshaft chain tensioner washer tel:07119963418 (1) Chain guide mounting bolt washer tel:07119963342 (2) (optional) s54 hub spring 11367830684 (1) Valve Cover Gasket Kit - erlang http://www.ecstuning.com/BMW-E46-M3-...Kit/ES2586868/ OR (1) OEM Valve Cover Gasket Kit - https://www.ecstuning.com/b-genuine-...FQpMDQodjcsBxg Labor ran me $600 with an Indy that came to my house. Hope that helps! |
12-10-2021, 12:55 AM | #5 |
Rep 5,327
OP, well done, i look forward to doing this when my time comes, cars sub 20k miles are the moment so ill look at it , at around 40k.
FYI, those wheels in silver are just money...... ive got some new wheels on order and i look at this pic and ask myself why am i spending so much when these are so perfect for this car?? merry xmas guys.
