08-25-2011, 01:44 PM | #3 |
Crazy Russian Bastard
30
Rep 819
+1
B
M W |
08-25-2011, 02:30 PM | #4 |
Moderator
94
Rep 1,920
In short, probably not. lol
You can get something that will work for under $400, but it wont be able to power much. Even a 1000 watt gen (in your price range) wont be able to power much more than a small tv or a radio and a couple of lights. Watts = Volts x Amps, so you can figure what you need in shopping for a gen.... Thus, if you are using 110 volt stuff, you have about 9 amps available, MAX. Not much...
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
08-25-2011, 03:53 PM | #6 |
Rep 1,369
http://www.yamaha-motor.com/outdoor/...or/sizing.aspx
should help decided on a size for you..
08-25-2011, 08:25 PM | #8 | |
Rep 1,063
I rent right now so don't need anything that powers the whole house. Just the fridge, a light or 2 & TV or something |
08-25-2011, 08:40 PM | #9 |
Rep 5,728
Drives: 2019 M2 Competition
Go nuclear.
08-26-2011, 10:49 AM | #10 |
Rep 1,268
I can tell you 1200 watts is not even enough, even though most refrig today do not use more than 500 to 800 watts, it is not the continuous usage you have to worry about it is the power on surge that you will have problems with. When a refrig turns on the compressor it exceeds the 1200 watt rating of the generator for a short period of time so it trips the breaker. Most generators can not handle motors inductive current draw so they trip off if you do not have a big enough generator.
Also if you go to a large one, most have a 10 or 15 amp breaker on the 110V out lines so they could trip when you have too many things being powered off them and the motor turns on. Very few have separated circuits for each 110V outlet, some have 220v and 110V outlets. With that said if you not looking at 3000 watt or greater it will not support a refrig and other things in your house. I have a 4000 watt generation with 220V out as well as 4 110v outlets. To make it easy I have wired it into my house main on the 220V side, but this requires disconnecting the house from the main power, not something I do not recommend unless you have a clue what you are doing. Last edited by Maestro; 08-26-2011 at 01:59 PM.. |
08-26-2011, 02:25 PM | #12 |
ahat
1036
Rep 2,592
current ebay deal for another few hours
http://cgi.ebay.com/DuroMax-4400W-Po...68660.m2000036 DuroMax 4400 Watt Portable Gas RV Power Generator Power When You Need It The Most! FREE SHIPPING! 300$
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
