      08-06-2018, 12:29 PM   #23
DataStream18
Drives: 2003 ESS TS1 Z4
Bump
      08-11-2018, 03:12 PM   #24
DataStream18
bump
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      08-14-2018, 04:13 PM   #25
DataStream18
Bumps
      08-20-2018, 04:41 AM   #26
DataStream18
Bump
      09-21-2018, 11:14 AM   #27
DataStream18
Replaced/fixed (?) the GM5 board, replaced the drivers side door actuator and boden cable.
Also price drop!
      10-06-2018, 09:56 AM   #28
DataStream18
Bumps
      10-06-2018, 10:56 PM   #29
gmbbs
Drives: TBD
PM sent.
      10-09-2018, 11:08 AM   #30
DataStream18
Price drop
      10-12-2018, 03:34 PM   #31
DataStream18
Not a single bite. Crazy
      10-15-2018, 07:02 AM   #32
DataStream18
Bumps
      10-17-2018, 11:58 AM   #33
DataStream18
yup
      10-25-2018, 01:50 PM   #34
DataStream18
I'm starting to wonder if someone knows something I don't. hmmm
      10-28-2018, 06:09 AM   #35
DataStream18
Sale was pending but we couldn't come to an agreement on price so shes still up for grabs.
thanks
      11-02-2018, 09:40 AM   #36
gmbbs
Drives: TBD
Hey, Can you give some specifics?
Details on Ground Control suspension?
Wheel size, tire size, tire brand?
A "trick LSD" is mentioned, what are details on that???
Thx.
Greg
      11-02-2018, 05:25 PM   #37
DataStream18
Thx.
Greg
I believe i sent you a PM when you asked a while back?
Shoot me an email datastream18@gmail.com
      11-05-2018, 08:53 AM   #38
gmbbs
Drives: TBD
That's what I thought too, but went back and nothing in my inbox, or in sent folders...??? *shrug*
Can you elaborate for the hoi polloi?
      11-06-2018, 03:51 PM   #39
DataStream18
he wheels are 18x10 (265x35) in the rear and the fronts are an 18 x 9 (345x40) Michelin pilot sport A/S 3+. The car has a limited slip differential in it with different gears 3.46 4pk,. The car had drop springs with OEM struts (I believe) the ground control is in the sway bar endlinks and a few other bits. I have a Google drive with a lot of the paperwork for the car attached to include a car fax for a week or.two ago as well as a boat load of pics
You can text me for a faster response as well as email 5176141209 datastream18@gmail.com
      11-13-2018, 01:09 PM   #40
DataStream18
bump
      12-03-2018, 06:42 PM   #41
DataStream18
bump
      12-31-2018, 08:05 PM   #42
DataStream18
bump
      01-02-2019, 06:37 PM   #43
Waoudi
Waoudi's Avatar
Drives: '17 X5 MSport, '16 M3 ZCP
What color is the dip? Thanks!
      01-10-2019, 05:32 PM   #44
DataStream18
frozen blue was the name.
https://www.dipyourcar.com/products/frozen-blue-kit
