      01-08-2019, 01:54 PM   #1
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Suggestion on N52 headers
Hello Z folks
Since Ontario Canada have no more emission control I decide to upgrade headers on my engine. Need you advise on what should I go with for my N52 3.0si engine headers
Brand, price.
Best regards
      01-08-2019, 02:39 PM   #2
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Believe supersprint has the only real plug and play set avail for the si...best time to buy is Black Friday, huge discounts on super sprint items
      01-08-2019, 05:35 PM   #3
Steeler
Steeler's Avatar
2429
Originally Posted by AK72 View Post
Hello Z folks
Brand, price.
Best regards
Andrey, I also think SS are the only ones that are made for the Z4. Others have adapted E90 headers but require some fab.
SS header not cheap.
      01-08-2019, 05:42 PM   #4
AK72
AK72's Avatar
David
I guess we missed train for this year, I will look around for the pricing.
Thanks
      01-08-2019, 05:44 PM   #5
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
Ontario emission testing is done as of April /1/19 .
      01-08-2019, 05:46 PM   #6
AK72
AK72's Avatar
Yes I know but my next one is in july so I should be fine
      01-08-2019, 06:13 PM   #7
Steeler
Steeler's Avatar
2429
David
Thanks
Andrey, just as an FYI I have used Schmeidman in Europe for a few parts in the past with great results both in communication and speed of shipping. Most of the Z4 parts from SS are made to order due to the limited market and Schmeidman has a direct line to the factory in Italy.
Not cheap but they have deals on occasionally also.
I paid zero duties when I bought my section 2 and silencer
https://old.schmiedmann.com/Z_series...age7.htm#18477
AK72286.00
      01-08-2019, 06:45 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
Wow! Good for Ontario!
"Ontario is cancelling the Drive Clean passenger vehicle program and avoiding taxpayers costs up to $40 million a year." ...
"While Drive Clean effectively reduced vehicle pollution, auto industry standards have significantly improved since the program was created in 1999 making this program no longer necessary."
Too bad I'm in Ontario California.
      01-09-2019, 06:57 AM   #9
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
I have the supersprints on my N52 and they are crafted beautifully but they 100% do not come with flanges to mate to the rest of the cat back exhaust. I believe they were designed to be fitted with all supersprint exhaust components. So you still will need a bit a fab work to mate them to the complete exhaust system.
AK72286.00
      01-09-2019, 08:40 AM   #10
AK72
AK72's Avatar
So it seems to me headers change won't be enough since they not made them as direct swap for our exhaust ?
      01-09-2019, 11:48 AM   #11
Steeler
Steeler's Avatar
2429
Sounds that way. I do not have SS headers.
You may not want to run catless. Could not stand the smell honestly when first putting the headers on.
What I ended up doing is buying the Magnaflow section 1, cutting off the flanges and clamping slip flanges on to the ends to match the header flanges.
From there I used the SS section 2 with 2 into 1 - 3" and silencer.
https://www.hottexhaust.com/Magnaflow_51725
https://old.schmiedmann.com/Z_series...11.htm#1973240
AK72286.00
      01-09-2019, 01:00 PM   #12
3002 tii
3002 tii's Avatar
2288
I had SS headers on my n52. Loved the bump in power but 2 things to keep in mind. Unless you spring for their section 1, it won’t mate up to your oe pipes in PnP way. Though it shouldn’t be difficult for any decent exhaust shop to fab something up.
Secondly, I don’t know if it was software or the physical location of the bungs but for longest time I had a fluctuating idle (and it definitely was not due to a vac leak). Ultimately I installed an o2 sim for separate reasons related to my tune but that actually eliminated most it not all of my idle issues.
The odor from catless is mostly noticeable when you’re sitting at a light but if you retain your factory secondary cats (section 1), it shouldn’t be that bad. Can’t confirm because I went full catless day 1 but I’ve sat in E90’s that did have their secondaries still intact and it was really tolerable. Also for sound reasons alone I’d keep the secondaries else you’ll probably have some drone.
Follow for latest mods
AK72286.00
      01-09-2019, 01:35 PM   #13
Steeler
Steeler's Avatar
2429
I should clarify that I have a 3.0i so different configuration than the 3.0si
      01-11-2019, 06:51 PM   #14
garz747
Iconicars in T.O. has an ad on kijji for exhaust header work on the S54, I would check it out...
      01-13-2019, 10:14 AM   #15
AK72
AK72's Avatar
I have n52 3.0si but thank you
      01-13-2019, 03:35 PM   #16
RossBMWZseries
I’m thinking of getting these headers for my E92 N52. $599 and from others’ posts in IG, they do a good job, high quality welds, sound good, and give a good power increase. Now sure if they’d fit the Z4.
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
AK72286.00
      01-14-2019, 08:10 AM   #17
garz747
I meant if they can do work on the S54 exhaust they can surely do the N52 also...
      01-14-2019, 09:31 AM   #18
AK72
AK72's Avatar
Thanks, I will follow up with them on Z4 fitment
