08-04-2020, 10:59 AM | #1 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
Coilover/Camber Bolt Question
Quick question:
I'm getting a set of coilovers installed this Friday, and have a set of TMS camber bolts that I ordered, as well. For those of you who have used them, do you recommend installing the camber bolts (with all washers on the outside) at the same time as the coilovers, or hold off on the bolts until I take the car for the alignment? I'm thinking installing the bolts during the coilover install would make it simpler for the alignment shop... Thanks!
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals |
08-04-2020, 11:20 AM | #2 | |
Rep 2,861
Drives: Anything
08-05-2020, 08:28 AM | #3 |
Rep 1,373
It can sometimes be hard to get the amount of camber wanted even with camber plates if you're looking for a more extreme amount. Ideally I want about -3.4-3.6 for the type of track work my car sees. I could get that with my old GC coilovers and GC plates because I could run the car quite low. It also still allowed me a decent margin of caster adjustment. Most adjustable coilovers have adjustment knob that protrudes through the strut tower and with the opening of the strut tower being circular the more camber you load in the less potential caster you can get out of the car.
For me I use the bolts to get more camber at the bottom so I can run the strut more towards the center of the opening in the tower so I can therefore run more caster.
07 Z4 M Coupe AW/IR Last edited by F360C; 08-05-2020 at 09:31 AM.. |
XMetal1126.50 |
08-05-2020, 08:39 AM | #4 | |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
All the threads I’ve read seem to indicate the bolts can be a pain in the butt to install sometimes due to the holes not wanting to align when the rest of the suspension components are together. I’m trying to avoid causing the alignment shop a headache.
08-05-2020, 09:01 AM | #5 |
Rep 264
Make sure you factor in what tire you want to run as well in this equation. I did what u/F360C did originally when I got my coilovers and was fine. HOWEVER afterwards when I went to 275s upfront, I had to remove the extra shim due to tire interference on the strut.
08-05-2020, 09:36 AM | #6 | |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
kaybat125.50 |
08-05-2020, 09:39 AM | #7 | ||
Rep 1,373
I have been able to put them in in the past with the suspension on the car. It can be a bit hard to line up the bolts... suspension needs to be unloaded and you just need to loosen the upper knuckle to strut bolt and that gives you the play you need to line everything up. Quote:
07 Z4 M Coupe AW/IR |
No_Dominion_2174.00 |
08-05-2020, 04:07 PM | #8 |
Rep 264
FWIW, I'm on FA 500s, (can't afford fancy MCS ) using their supplied plates. I had to remove the shims to get the 275s to fit, and even had to go back to near stock ride height to stop fender rub under full compression, leaving me maxed at -2.3.
ninja edit: running apex sm-10s 18x9.5 et-35 square, 5mm spacer in the rear I believe I will rebuild them before next year (or go another route, who knows haha) and if I do, I intend to get different camber plates and shoot for -3+ again upfront
08-10-2020, 06:20 AM | #9 |
Rep 484
To answer your question, not difficult to install after strut install. If it were me, I would install them. On my street car I have PSS10’s that don’t have camber plates so I installed shims to kick out the knuckle. 255 tires clear fine. On my track car I don’t have shims due to strut clearance for 275’s.
08-10-2020, 10:43 AM | #10 | |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
