05-02-2022, 03:25 PM | #45 |
Rep 783
I got the strut brace back from the powder coaters today, I'm okay with it for now but I may have another stab at it later. Not sure I like the add on modification, it would be nicer to have a more unified look. I'm certainly open to suggestions.
2008 E86 M coupe
wdb4736.50 |
05-03-2022, 02:58 PM | #46 |
Rep 783
The bearing puller/pusher arrived today, everything is good quality except the threaded rods, those pointy threads are going to gall and wear out quickly I think.
Just in case that happens I bought some acme threaded rod and nuts to replace any stripped rods.
2008 E86 M coupe
belcom178.50 racerbruce3854.50 |
05-11-2022, 03:50 PM | #47 |
Rep 783
The headlight lenses that ordered off of ebay arrived today, I thought I needed them so went ahead and ordered but ended up re sanding and polishing the original lenses.
Quite surprised to find they are very well made, exact copy as far as I can tell, same thickness. Not sure if the material is the same but looks to be. Up onto the not needed BMW shelf they go.
2008 E86 M coupe
racerbruce3854.50 |
05-11-2022, 04:10 PM | #48 | |
Rep 2,705
Fit the headlight buckets perfectly.
05-11-2022, 04:43 PM | #49 |
Rep 783
If you don't mind I'll use your quote in my for sale ad
2008 E86 M coupe
Steeler2430.00 racerbruce3854.50 |
05-11-2022, 06:22 PM | #50 |
Rep 2,705
It's out in the ether. Fair game
racerbruce3854.50 |
05-12-2022, 10:46 AM | #51 |
Not great. Not terrible
7446
Rep 2,700
Can you please share how you did that? I was considering buying his lenses but when I saw one video on the process, it was more than I can tackle. Maybe there's an alternative way that would be in my wheelhouse.
Current: 2024 BMW X3 M40i.
05-12-2022, 05:12 PM | #52 | |
Rep 2,705
Not that difficult once you heat up the adhesive. The original lenses were literally falling away from the headlight bucket when I opened the oven. Be diligent cleaning out the old adhesive in the channel. I followed this And then this Your results may vary. Good luck.
JustinHEMI7446.00 |
05-21-2022, 09:57 AM | #53 | |
7446
Rep 2,700
///M Power-Belgium63644.00 |
05-21-2022, 06:20 PM | #54 | |
Rep 783
Let me know, thanks
2008 E86 M coupe
tomjonesBT33177.00 |
06-04-2022, 01:03 PM | #55 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Epic refresh! Reminds me of some E39 M5 projects on M5board.com.
This car won the owner lottery!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
grannyknot953.00 |
06-04-2022, 03:31 PM | #56 |
Rep 783
I have been looking around the online dealers trying to find a new OEM D/S door seal, it's a bit of a unicorn. Finally found one yesterday in Lithuania so I should have it in a couple of weeks. The seal on the left door is working fine atm but there is wear hole where the drivers feet have worn through getting in and out of the car. Also, some sun damage on the upper part of the B pillar. I can only see these kinds of things becoming harder to find so gathering them up now.
2008 E86 M coupe
06-04-2022, 07:38 PM | #57 | |
Rep 3,286
06-06-2022, 03:45 PM | #58 | |
dances with roads
4737
Rep 4,099
06-06-2022, 04:02 PM | #59 |
Rep 783
I had a look around the usual online dealers, most of them say "back ordered" and a few say NLA. Ebay is always my last option.
2008 E86 M coupe
06-06-2022, 04:44 PM | #60 |
dances with roads
4737
Rep 4,099
I have a 996 Porsche 911 with high miles and I'm putting a lot of parts on it. I am seeing supply issues. I found a really good European source which I have found to be useful when the stateside folks say "backordered". Sounds like I should try to find one for the zed too.
grannyknot953.00 |
06-07-2022, 11:51 AM | #62 |
dances with roads
4737
Rep 4,099
Gert Carnewal, but he's a P Car person only I think. Amazingly fast shipping; remember that there will be import duties to factor in to the final price.
http://www.carnewal.com/ |
06-25-2022, 06:37 AM | #63 |
Rep 783
A few things came in the mail, the OEM D/S door seal, some LED lights for the interior and the new speakers for the doors and behind the seats.
The LED bulbs are brighter than the incandescent stock bulbs and run much cooler, while I had the roof lights out I found this bundle of wires stuffed up in the headliner, there are telephone connectors on it for an in car phone I guess. The midrange and tweeters are of the Bang-Olufsen design that are used in the new BMW cars but although I have to assume that they are knock offs the construction and sound quality are excellent, better than the stock units. They are labeld Made in Germany but arrived from China, $40 a piece for the midrange, $28 for the tweeters The 4" midrange are drop in replacements for the doors and above the subwoofers behind the seats, the tweeters are a bit larger so some modification of the tweeter mounts was necessary. In the pics the stock units are on the left. I'll wait until the winter when I pull the seats out to replace the rear speakers but everything sounds good now. I'm still trying to eliminate the smell of the PO cologne so am keeping a open bag of BBQ charcoal in the car when not in use, so far it seems to be helping.
2008 E86 M coupe
wdb4736.50 |
06-25-2022, 07:05 AM | #64 |
dances with roads
4737
Rep 4,099
Maybe the wires were for a radar detector?
grannyknot953.00 |
06-25-2022, 08:24 AM | #65 |
Rep 3,004
Nice -
This looks nicer than most....clean, simple lines - very bespoke.
Racerbruce
grannyknot953.00 |
06-26-2022, 04:10 PM | #66 |
Rep 783
Every time I drive the car I noticed these smears of something on the inside of the instrument cluster lens. I found some time today to pull the cluster, dismantle to get the lenses out, looks like someone got carried away with spraying an interior protectant.
While I had it apart I was temped to black out that irritating flashing tire inflater light but I think I'll wait until I can find someone who is good with INPA get him to code it out.
2008 E86 M coupe
wdb4736.50 |
