      08-30-2017, 11:59 PM   #1
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
Fuse box question
I'm looking to wire up a dash cam in my Z4MC. Right now I can plug it into the cigarette lighter but unfortunately this is always hot and stays on even when the car is off.
I have a fuse "add a circuit" on the ready but I'm wondering where to try it. I want the camera to turn off when the car is not running and turn on when it is.
Where do you guys suggest I plumb this in on the fuse box?
      08-31-2017, 07:29 AM   #2
Drives: E86 Z4MC; E92 M3
The easiest thing is to go through the fuse rack with a tester.
      08-31-2017, 09:42 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Name:  2004 BMW Z4 (E85) Color Fuse Diagram.png
inTgr8r1349.50
ried550.50
      09-01-2017, 08:29 AM   #4
mainsoda
mainsoda's Avatar
Thanks StickMon!
      09-01-2017, 11:19 AM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
I can't take full credit.
Another Forumite went to the trouble of making it.
I just keep a copy close at hand.
      03-25-2018, 03:52 PM   #6
powaq
Drives: E86 Z4 3.0si
As I would like to add a circuit on my car as well, I was wondering where to attach the ground wire. Anybody has any suggestions (I would probably be putting the device in the wall between cabin and trunk on a coupe)?
Also would fuse 9 be empty with a manual car?
      03-25-2018, 11:39 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Well, I was going to consult the WDS, but it needs Java, and Java appears to be an evolutionary dead end.
Grounds are usually solid brown. Find a connector near where you need it, find a solid brown wire, and ohm it out to the chassis.
Not sure about fuse 9. Seems that it would be extraneous with a manual.
On a related note, anybody know of a good post-Java solution to the WDS?
      03-29-2018, 05:20 PM   #8
mainsoda
mainsoda's Avatar
I forget where I put my ground, there were a number of chassis screws nearby. I used spot F2.
      04-04-2018, 08:49 AM   #9
elerner61
elerner61's Avatar
81
Drives: '07 Z4M Roadster
Why not tap into the power/ground in the rear view mirror/light circuitry? Think this video has the info I used when I did mine.
      12-28-2018, 12:31 AM   #10
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
I was wondering the same thing. My daughter got me a dashcam for Christmas and now I need to figure out how to get it wired in. The wire mentioned in that video to tap into, what does it go to?
2006 Z4M Interlagos Blue/Beige
      12-28-2018, 12:46 PM   #11
XMetal
XMetal's Avatar
Drives: '04 X5, '08 Z4MC
2008 Z4M Coupe  [0.00]
2004 X5  [3.50]
The mirror is where I tapped into for my radar detector. For the dash cam, I had to tap into the fuse box because it only takes 5V, so some type of step-down voltage regulator was required - either a cigarette lighter type or a straight dedicated 12V to 5V regulator box. Either solution would be too bulky to be stuffed in the overhead. Also, if you already have a radar detector tapped into the mirror circuit, you wouldn't want to take the chance with over-loading it with more accessories.
I did something similar to this for my dash cam
      12-28-2018, 01:06 PM   #12
gpraceman
gpraceman's Avatar
No radar detector to worry about.
I ordered this wiring harness, which includes the 12V to 5V convertor. I was hoping to stuff that into the area behind the map light. Trimming off as much of the wiring before the convertor as I can.
      Yesterday, 11:28 AM   #13
RobMCoupe
RobMCoupe's Avatar
39
Drives: 2007 Z4 M Coupe
I installed Blackvue recently with PMP for parking mode. I tap into the two empty slots on the fuse box. There are bolts there you can use for ground.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
