05-12-2014, 12:10 AM | #1 |
Rep 69
Stuck Valve cover gasket
I have been trying to remove the valve cover gasket after I unbolted all the aluminum screws, it still seems to be stuck in place.
Does the the ground stud have to be removed? (below). There are two and it looks like they require a deep socket which I need to buy. |
05-12-2014, 11:15 PM | #2 |
636
Rep 3,124
Trying to remove the head cover?
Don't those coils have to come out first? I've only taken apart the S54, but this makes it look like the coils have to come out, along with the wiring to the ground studs.
05-13-2014, 02:22 PM | #3 | |
Rep 69
Btw, the ground studs required a 10mm deep sockets to come out. |
05-13-2014, 02:45 PM | #4 |
Rep 417
Did my gasket a few months ago. Had to remove those two bolts to remove cover. It's not just the gasket stopping you from removing the valve cover......
Sent from my smart phone...
05-13-2014, 03:05 PM | #5 | |
Rep 69
While removing the injectors wire-harness, I found oil inside the connectors Did the oil leak come from the injectors up to the connector? What cause is it? |
