      07-19-2018, 05:25 PM   #1629
paulromi
Drives: 2006 Z4 E85, 2011 328xi E90
Originally Posted by pcube View Post
Gave my ///M a little refresh on her 10th birthday!
Paint job
Windscreen and rear quarter glass
Roundels front and back
Windshield lower cowl
Window weather strips
Solar film
Valve cover emblem
Alpine Halo9 stereo and aftermarket amp
Another question on the Halo 9. Do all the steering wheel controls still work?
      07-20-2018, 11:33 AM   #1630
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Sadly, no. I bought the PAC SWI-CP5 and had it installed at the same time and it does not work.
      07-24-2018, 10:05 AM   #1631
dre99gsx
Drives: 1994 Toyota Supra
hood vent splash gaurds
Not bought, but custom made using some aluminum
Azeka1285.50
      07-24-2018, 10:55 AM   #1632
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
Getting ready to flush all of the fluids this weekend. Once I bed her down for the winter, I am looking to do the valve adjustment and VANOS rebuild.
2006 Z4M Interlagos Blue/Beige
      07-24-2018, 11:47 AM   #1633
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
You added some vents and then blocked it off?
wdb4721.50
      07-24-2018, 08:50 PM   #1634
dre99gsx
I did!
To be fair, they are not fully blocked off, but hot air can still escape through the openings on normal driving / car wash / trailer hauling.
Once at the track, splash shields come right off with just 6 screws You can see I have quite a bit of stuff that sits right under the shields and cannot get wet. (that air filter would get completely drenched)
I also don't like water tricking in there as I'm seeing rust on some body and frame pieces. No bueno.
      07-26-2018, 06:52 PM   #1635
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Apex ARC-8 wheels in hyper silver 18" for street use...now to find tires!
      08-01-2018, 12:31 AM   #1636
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Camshaft position sensor & oil change!
      08-01-2018, 03:32 PM   #1637
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
My Grandma, that's a big motor you have.
      08-01-2018, 03:33 PM   #1638
elerner61
elerner61's Avatar
157
How did your CPS go? Quietly and throw a nice, specific code? Or did you have to call a flatbed of shame?
      08-01-2018, 03:38 PM   #1639
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Started my car and bam code popped up haha
      08-07-2018, 12:54 AM   #1640
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
AKG motor mounts (after my VT mounts failed and they won't reply to my 3 emails) oh well..
StickMon636.00
      08-07-2018, 01:47 AM   #1641
StickMon
StickMon's Avatar
Drives: 2006 MR
AH HA!
So I'm not the only one to have failed VT mounts!
And you're correct. They are not repairable, contrary to their original statement.
There's a thread here someplace on my switch to BimmerWorld and my custom heat shield.
      08-07-2018, 11:51 AM   #1642
gpraceman
gpraceman's Avatar
Doing a flush of all fluids for Inspection II. Changed out transmission fluid, differential oil, power steering fluid, brake fluid, and coolant. Will wait on the oil change until after I do the valve adjustment and VANOS rebuild. Also replaced the A/C belt. The Royal Purple Synchromax that I put into the transmission has made shifting smoother.
      08-08-2018, 05:56 PM   #1643
gpraceman
gpraceman's Avatar
Also, I built these from some 2x8 and 2x4 lumber so I could get my floor jack under the front jacking point. They worked well and were pretty inexpensive. From there I was able to get the front onto jack stands.
HTM10157.00
Azeka1285.50
      08-09-2018, 06:30 AM   #1644
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Built myself a pair like that a while ago. Makes life much simpler.
      08-09-2018, 11:22 AM   #1645
wdb
dances with roads
wdb's Avatar
4722
I have single thickness pieces, which worked fine on other cars in the past but which I now know aren't enough for this car. Off to the lumberyard.
      08-09-2018, 09:20 PM   #1646
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Bimmer World solid shifter to match the Turner Motorsports solid engine & trans mounts.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      08-09-2018, 09:50 PM   #1647
couchflyer
couchflyer's Avatar
97
Drives: M4; X4 M40i
I retro fitted cruise control on my Roadster.
      08-10-2018, 08:18 AM   #1648
Hawkeye
Hawkeye's Avatar
No_Country
2070
New Serpentine belt, rear shocks, rear tires, oil change, various fluid flushes. Looking to do the windshield trim here in a few weeks as well after seeing a good thread about that.
      08-10-2018, 03:38 PM   #1649
tcnmtn
Drives: Z4M Coupe
Stromung
Stromung mufflers for my Z4M coupe.
      08-10-2018, 04:11 PM   #1650
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
CSL airbox =)=)=)
Edit : Canceled because Epic Motorsport said it's not worth it.. getting a 3.91 diff instead.
Azeka1285.50
