05-14-2021, 09:07 AM | #45 | |
Rep 3,519
///M Power-Belgium63331.00 M5Rick60023.50 |
05-14-2021, 09:13 AM | #46 |
Rep 19,533
Theres a song called ''Some guys have all the luck'' (with the helpful hand of others who are in cahoots) I'm thinking of putting it on..
///M Power-Belgium63331.00 |
05-14-2021, 09:22 AM | #47 | |
Rep 2,665
RB has a spoiler that passed all tests and "rigid" isn't a binary, yes/no function. Take any of these cars over a curb, have gauges to measure deflection and you will find that virtually nothing is rigid. You want something that doesn't bend under a certain amount of load you need to put the numbers in the regulation and test for these numbers. Only thing I can see from the video is the RB wing is more flexible than the MB and the MB fin seams to be more flexible than the RB. I don't for a second think MB has this flexible fin because they don't realize it or can't fix it. Too simple to make it less flexible if it would help them.
Killed by Death12425.00 MKSixer34184.50 |
05-14-2021, 10:15 AM | #48 |
Rep 24,659
Regarding the 16-B flexible rear wing :
It Isn't flexible , because the "whole rear wing" is moving downwards . "IF" the rear wing was flexible , only the middle section of the wing would be curved downwards ! The reason why the Red Bull wing is moving downwards is because the 16-B is running with the well known "higher rake" In other words : By the Red Bull's higher rake , the rear wing is catching more wind . That's why we can see that the whole wing is moving downwards by the higher downforce on the rear wing . HAM and Toto are talking BS as usual...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick60023.50 Killed by Death12425.00 |
05-14-2021, 10:24 AM | #49 | |
Rep 19,533
It's why the W12 has been tail happy at first with their longer wheel base and higher rake thus using the McLaren diffuser to even it out and taking longer to warm their tyres whereas RB tyres up quicker. |
///M Power-Belgium63331.00 Killed by Death12425.00 |
05-14-2021, 11:29 AM | #51 |
Rep 19,533
05-14-2021, 12:00 PM | #52 |
Rep 24,659
The Mercedes "Warp-Speed Knowhow" isn't visible , because It's hidden under the W12 PU cover ...
That's what we are talking about , and that's why HAM is leading in the drivers rankings with a lot of luck on his side ! It's there where the FIA should look at ....
05-14-2021, 12:15 PM | #53 | |
Rep 19,533
05-14-2021, 12:27 PM | #54 |
Rep 2,665
I'm assuming the static load test is done by pushing on an area of the wing and measuring deflection (correct me if I am wrong). You say RB are cheating the test, can you explain how? Only way I can see that you can say they are cheating the test is to understand how they did it or have some additional information besides just watching a wing go down more than another wing.
05-14-2021, 02:17 PM | #55 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
Neat! It looks like they(RBR) knew how the FIA tested this and figured out a way to pass the test and still gain an advantage. This is engineering. As a result the FIA will tighten the testing up to eliminate this grey area/loophole. I'm not mad about it. Nice work RBR
Killed by Death12425.00 ///M Power-Belgium63331.00 |
05-14-2021, 02:45 PM | #56 |
Rep 3,519
05-15-2021, 04:56 AM | #57 | |
Rep 4,381
So other teams who might have scored more constructors points (along with the $millions that brings) if Red Bull hadn't been cheating...you thing they are equally impressed by Red Bulls "engineering"? And if Red Bull have the moral duplicity to cheat at one aspect of their cars design then why wouldn't they cheat at others? |
05-15-2021, 05:31 AM | #58 |
Rep 19,533
^ You could say that about the Merc hidden warp speed to which other teams are losing out on points, well hidden under those engine covers if Merc are cheating at that hiding it well and being passed as 'legal' like the Das scam.
05-15-2021, 07:19 AM | #59 | |
Rep 24,659
Most of his crashes were caused by his crappy HAAS car !
05-15-2021, 08:37 AM | #60 |
Rep 19,533
05-15-2021, 08:53 AM | #61 | |
Rep 3,204
05-15-2021, 08:58 AM | #62 |
Rep 24,659
Spot on mate !
05-15-2021, 09:06 AM | #63 |
Rep 19,533
05-15-2021, 09:16 AM | #64 |
Rep 24,659
Rainbow trout here...
Killed by Death12425.00 M5Rick60023.50 |
05-15-2021, 09:46 AM | #65 | |
Rep 3,519
Still hoping HAAS can pull off a miracle in 2022. My second favorite team since I live about 20 minutes from their US factory. MAYBE Ferrari can produce a great engine without cheating next year. But I doubt it |
05-15-2021, 10:12 AM | #66 | |
Rep 24,659
Also for his wife and kids , after such a hard time.. No wonder he crashed so much in the Haas car . The Haas car is very unpredictable ! On the other hand : I've watched the 30 episodes (3 seasons) of Drive To Survive .. I mean the driver Kevin Magnussen did an oustanding job at Haas in that crappy car ! If Checo fails at Red Bull , Horner should make that call for Kevin Magnussen ASAP ! Kevin is such a nice guy and his driver performance is really underestimated ... Hopefully we can see Kevin back in F1 ASAP ! EDIT : Ferrari ? Well , Ferrari did a big step forwards ! Look where they came from...And look where they run today !
