      06-14-2019, 06:11 PM   #1
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Anyone know what these error codes are?
Car had 3 owners, some after market stuff, don't know if he might done a CDV delete but that's just a wild guess.
These are the codes under ECN (Engine Control Module - DME/DDE):
- 2ACC DME: DME master relay, shift delay
- 2CFA DME: Throttle-valve potentiometer 2
- 2D09 DME: Throttle Valve
- 2D1D DME: Accelerator-pedal module, pedal-travel sensor 1, voltage supply
- 2F45 DME: Interface EWS-DME
These are the codes under ABS (Anti lock braking system - DSC)
- 5DF4 Battery voltage too low; open circuit
- 4E1F Control unit: incorrect vehicle identification number; calibration required
- 5E16 No message, IKE (610,613 or 615)
Scan Creator C310+
If anyone knows what these are, would be great!
Cheers
      06-14-2019, 06:16 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Did you clear the codes and see what comes back?
Some could have been 1-offs.
A bad Throttle-valve pot will sometimes throw the Throttle Valve code because it can't decide which one is wrong.
Dav3948.50
      06-14-2019, 06:28 PM   #3
Dav3
Dav3's Avatar
949
Haven't yet, will do tomorrow.
I'll bring it down to official BMW dealership soon too though.
Hopefully all these codes are not that major!
      06-17-2019, 11:36 PM   #4
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Reset them, drive for a bit, see what comes back. Stealer will charge you to diagnose.
