06-14-2019, 06:11 PM | #1 |
Rep 1,027
Anyone know what these error codes are?
Car had 3 owners, some after market stuff, don't know if he might done a CDV delete but that's just a wild guess.
These are the codes under ECN (Engine Control Module - DME/DDE): - 2ACC DME: DME master relay, shift delay - 2CFA DME: Throttle-valve potentiometer 2 - 2D09 DME: Throttle Valve - 2D1D DME: Accelerator-pedal module, pedal-travel sensor 1, voltage supply - 2F45 DME: Interface EWS-DME These are the codes under ABS (Anti lock braking system - DSC) - 5DF4 Battery voltage too low; open circuit - 4E1F Control unit: incorrect vehicle identification number; calibration required - 5E16 No message, IKE (610,613 or 615) Scan Creator C310+ If anyone knows what these are, would be great! Cheers Last edited by Dav3; 06-14-2019 at 06:26 PM.. |
06-14-2019, 06:16 PM | #2 |
636
Rep 3,124
Did you clear the codes and see what comes back?
Some could have been 1-offs. A bad Throttle-valve pot will sometimes throw the Throttle Valve code because it can't decide which one is wrong.
Dav3948.50 |
06-14-2019, 06:28 PM | #3 | |
Rep 1,027
I'll bring it down to official BMW dealership soon too though. Hopefully all these codes are not that major! |
