10-14-2015, 02:48 PM | #24 |
Rep 5,058
Something is definitely wrong with my camera or lens. I took it in to Canon factory and they had determined that they need to realign the lens because it had shifted. Majority of my photos on the left side are out of focus.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
10-14-2015, 03:00 PM | #25 | |
Rep 7,389
Don't forget to use Digital Lens Optimization during Raw conversion to automatically correct of geometric lens distortions, chromatic aberration, vignetting, etc. at every focal length and every aperture. DLO is a module include in Digital Photo Professional, that ships with every Canon dslr. Dave
10-14-2015, 03:08 PM | #26 | |
Rep 5,058
http://www.usa.canon.com/cusa/profes...vice-locations Look at the last two pictures and see the left side of the photos.. See how it is out of focus yet the other side is crisp? I took the camera in this morning and the Canon tech told me that they need to check the focus compensation on the camera body and lens. They will keep it for several days and repair it. The good thing is it is under warranty so they will take care of it.
10-14-2015, 03:19 PM | #27 | |
Rep 7,389
Yeah, best bet is, get it fixed by them. Dave
10-22-2015, 08:15 PM | #28 |
MDavey Photo
19
Rep 82
Some great shots. Everyone overdoes it with the clarity/shadows when they're first learning. I was a victim of it too, and I look back now and ask myself how I thought that looked good. I always try and help others out, but you can only give so much advice on it until a majority of people take offense. You'll learn more as time goes on.
As time goes on you'll also learn more about aperture and depth of field. Normally you would say the left/right side issue was that, but since the car on the left side is very similar to to the distance away from you as the car on the right, they should be almost identical for how out of focus they are. You can easily test this out. Set something up similar to this, having 1 object centered, and then two other objects on the far left and far right. Don't zoom the lens at all or crop. Have the side object to the edges of the frame. Side objects should be the same distance away from the lens. Shoot the same shot at f/3.5, f/5.6, and one above f/8 all focused directly on the center object. If all of the images, both side objects should be identical as far as how out of focus they are. If they aren't identical, something is messed up. *You can also try shooting with the right object in focus at f/3.5, and the left object should be just as sharp. If the left is out of focus you know something is jacked up. If you ever have any questions on gear, understanding something, editing, etc feel free to let me know. A lot of photographers are assholes and don't like to help anybody as if they know some secret, I like to spread my knowledge and help out as I know what it's like to have nobody to ask things. I followed you on Flickr. I don't upload much as I'm picky and like to keep mine simple/clean. Just passed 1,150,000 views Mine - www.flickr.com/photos/23781526@N02/
10-23-2015, 08:23 AM | #29 | |
Rep 5,058
So I'm probably going to call canon again to have them adjust this...
10-31-2015, 06:43 PM | #30 |
Rep 5,058
I got the camera back and still not happy with the results... maybe I just can't seem to take crisp pics or this kit lens sucks and I need invest in a good lens..
Fall is in the air...
10-31-2015, 09:28 PM | #31 |
MDavey Photo
19
Rep 82
Are you sharpening at all in post? I went about a full year wondering why my shots weren't sharp at all until I realized my default settings were with no sharpening at all.
Also spent a few months with noise reduction turned on with my Canon 6D which was softening all my photos to reduce noise. Turned that off and it changed everything. If you want to email me one of your RAW files, I'll play with it a bit and see what I can come up with, and email you back the PSD file with the layers. The kit lenses these days are much better than 5 years ago and will still take amazing photos, but some new glass will blow you away. mdaveyphoto@gmail.com
11-01-2015, 06:21 PM | #32 | |
Rep 5,058
I just sent you and email on a perfect example RAW photo. Thanks for your help!
11-24-2015, 12:48 PM | #33 |
Rep 5,058
At a recent BMW meet. I realize lot of my shots are not straight and my composition sort of sucks.. Any guidance is appreciated!
11-24-2015, 02:26 PM | #34 |
Rep 1,049
If you're just starting out I would forget about post processing and focus on composition. Get a cheap 50 mm 1.8 prime, focus on framing simple, focused shots and just shoot in jpeg.
The colors are really distracting, but don't really matter if you don't have solid shots to begin with. You also have some strange vignetting on the upper left corner. Not sure if you are using too many filters or what. I would start by shooting single cars, not multiple and trying to think of what image you are trying to create when shooting. You can always learn by copying, too. Find images/angles you like on the internet and try to recreate them. You'll figure out what it takes to make that kind of image and start to understand why that image works vs. random shots. Btw, the interior of the X5 looks great. I really like the lower belt line look and the lighting effects. It would be cool if in a future M model they had an illuminated line across the dash that changes color when you enter M mode. |
11-24-2015, 03:22 PM | #35 | |
Rep 472
Secondly composition is mostly learned. Most of us are able to see and appreciate fine art but we can't come close to creating it. The easiest way to learn composition is to find images you find most pleasing and study them. The angle it was shot, where the subject is in the photo, where the horizon is if there is one. Look at what you find interesting and look at things like what is in focus and what isn't. How deep into the scene is the subject? With certain types of subjects or genres you will either want to see everything in focus (landscape) or just the subject (portrait). These effects are created by camera set up and lens choice. Lighting is also key. This can be natural or artificial. I could go on but what you need to do is read as much as you can. There are a lot of online tutorials that are free. There are some very good ones on editing as well. Lightroom is a good program for 98% of what most people will need. I was a pitiful photographer for years. Just out of pure ambition I pushed forward using my failures as opportunities to learn what didn't work and eventually finding things that did. There is likely a photography club in your region if you look online. I suggest joining up and learning from others in the field. Learning on your own takes 10x longer.
18’ 540i XDrive M Sport
https://www.flickr.com/photos/mik3ymomo/ |
11-24-2015, 05:43 PM | #36 |
Rep 7,389
I agree with the advice about learning about composition, but can't understand why you'd cripple yourself with a 50mm prime. I find 70-200mm to be close to ideal for 80+% of my auto shooting.
I think your images lack a little contrast. The exposure value is about right, but most look "flat" to me. Try working with the Contrast control. You might also try a modest S-curve in the RGB window. Be very sparing with Saturation and Sharpening. Make sure images are really sharp by looking at them at 100% and assuring that the focus is where you want it. I started with a 50mm, but that was the 1960s!! Zooms weren't near as good as they are today. To me, a 24-105mm and a 70-200mm really covers a lot of ground. To my eye, "portrait" focal lengths in the 70-150mm range work really great on cars. Dave
11-24-2015, 06:02 PM | #37 |
Rep 1,049
Agreed. Longer focal lengths are typically more flattering. However, the 70-200mm lens is an expensive one for a beginner (assuming F2.8). I would not recommend that as a learning tool. I think primes force you to deal with composition and are better for learning.
11-24-2015, 06:37 PM | #38 |
Rep 472
Part of composing a shot is getting in the right position. Folks learning with zooms get (are inherently) lazy and try not to move to get a shot. A prime lens teaches (forces) people to zoom with their feet and to walk around to and from a subject finding the right distance.
When you get people to start using their feet they get better at composition. I found this to be true. When I started out and people were talking about composition and recommending the 50mm; they said that too often people will act like their feet are in concrete. It would come to mind when I would catch myself leaning back instead of taking a step back while composing a shot. Unless I walk around a static subject changing levels, distance and angles; I never quite find the right perspective unless for completely dumb luck that I'm in the perfect spot to start. Of course there are many times that a zoom is the only way to get a shot. I can back up but so far when physical objects like a brick wall or other fixed object makes that impossible. Zooms give flexibility and I use several. If one can afford what we call the Holy Trinity of zoom lenses I highly recommend it. 14-24 F2.8 24-70 F2.8 70-200 F2.8 Most people I come across that are just starting out will object first to the prices of a pro lens, 2 then object to the size and weight of these pro zooms. Let's not forget we are talking about how to teach someone composition and a prime lens gets people moving around and moving around is where it all starts for excellent composition. A 50mm is light, compact, is in most anyone's budget that owns an SLR and the image quality being compared to the best glass available on the market is dollar for dollar the absolute best value around. You can read the reviews of the lens or look on DXO Labs website that shows the lens comparison tests of Canon and Nikon lenses rating them on resolving power, distortion, CA, Vignetting etc and see where those lenses fall in the top 20. The 50 will be the least expensive lens in the lot. It's earned that lens the nickname of the "Nifty Fifty" for decades and it stays true even today. That focal length inherently lends itself to excellent image quality where less complex glass elements are necessary to create a low distortion flat image that's sharp corner to corner with excellent Bokeh.
11-24-2015, 06:47 PM | #39 | |
Rep 472
11-25-2015, 01:13 AM | #40 | |
Rep 7,389
11-25-2015, 01:38 AM | #41 | |
Rep 7,389
Lazy?! Last week I walked for miles around New Orleans, with my 24-105 mounted on a full-frame body. I also carried the 70-200/f4 and the 15mm, but only used the 15mm once and that shot didn't really work out. It's interesting to note that the shots were in three focal length groups, 1/3 were 42mm to 60mm, about 1/3 were 24mm to 35mm and the other 1./3 were in the 70-105mm range. I could have carried three primes and walked a little more, but the perspectives would not have worked with a 50mm alone. 105mm Trolley 2012 by David Stephens, on Flickr 28mm Paying the band by David Stephens, on Flickr 45mm MM by David Stephens, on Flickr To me, each has a character of its own and walking closer or further away would not have improved it. Changing focal length is part of the character of the images. Dave
11-25-2015, 01:02 PM | #42 |
Rep 472
Dave,
The hardest part for a beginner in my opinion is they shoot everything from eye level and from the first place they find themselves standing when they bring the camera up to their eye. The idea here is to make them get into the habit of moving around to find the right perspectives. If you give a zoom to someone starting out they will mostly just frame the shot based on focal length alone and what that can zoom to or go wide on. It was the case when I started shooting and I believe it's mostly universal. Let me state I am just an Amateur and my opinion expressed should be taken as such. Lol |
11-25-2015, 08:39 PM | #43 |
Rep 7,389
Mike, good analysis.
I think that the big problem for beginners is composition and not focal length. Whether using fixed focal length or zoom the questions should be things like, is the frame full, are there leading lines adding strength, is there balance in the image, etc. Believe it or not, there was a time when we all had SLRs with 50mm lenses. My kit was a Pentax Spotmatic, a 50/f1.8 and a preset 200/f3.5 and I was in the minority with that telephoto. I didn't know anyone with a zoom until 1969 and he was a pro. People still made really shitty images back then, just like they do today. I think that telling beginners to change their perspectives and take several shots of the same scene is very useful. There are exceptions, but saying that shooting from the left or right or from a high or low perspective is almost always better than shooting straight, head-on. In my examples, I walked all around that street band and took maybe thirty images, but I think the strongest is the guy putting a buck in the bucket. I think that attention to composition is really important and that zooms are not the culprit, but a really great tool for all photographers. Dave
11-26-2015, 06:27 AM | #44 |
Rep 5,058
Thanks all for the suggestions.
