      08-10-2013, 08:26 PM   #1
brandobot
Drives: 06 Z4M
Fast blinking / lamp warning light on - can't turn off
My lamp warning light came on this afternoon on my 06 z4m roadster and the left turn signal began signalling faster than normal. Upon inspection, a part of the brake light bulb broke off, which is probably what threw the code. I have replaced the bulb and the light still says.
I have tried(and have not been able to get the light to go away:
-swapping all bulbs from left to right
-tried removing a bulb from right side to see if it would signal fast as well, but it continues to signal normally with bulb removed.
-headlights and the circular light in the headlight are functional. when I turn on the highbeams, the lights will flicker but the same projectors (outer) will light up. the inner projectors never turn on. Do the hi-beams use the outer or inner projector of the headlights?
-removed led license plate lights with oem bulbs
Is there a way to reset all the dash lights?
This is the light - 2nd row, 3rd image
http://cdn7.staztic.com/app/a/575/57...-s-307x512.jpg
      08-10-2013, 10:47 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Here's an explanation of the headlights.
Threw me, too, when I first got my car.
High beams are via a mechanical "eyelid".
The license plate lights are not monitored.
I think you still have a bulb out somewhere.
Make sure all 4 front turn signals are flashing. There's 2 on each side.
5 and 6 in the diagram.
      08-11-2013, 12:06 AM   #3
brandobot
Drives: 06 Z4M
Thanks. I"ll check the turn signals. I can't tell from the diagram, where are the two turn signal bulbs in the front?
      08-11-2013, 12:41 AM   #4
brandobot
Drives: 06 Z4M
cancel that. found that it was the driver side front turn signal... now to find a diy on how to change it
